QuantumRebelX
- Oct 15, 2024
I can verify for sure that the reflector LED headlights do NOT have any type of LED halo. Will send pics when i can. (not to say they don't look cool, the lighting is actually pretty good, would just like that halo signature)LED tail lights are the only ones capable of having the animated feature for sure. I’m almost positive that the projector headlights found on limiteds and tungsten’s are the only ones capable of the animated feature.
For both the rebel and the laramie, incandescent tail lights are standard. Level 2 package for the rebel, and night edition package for the Laramie are the packages that list exterior front and rear light animation, but there is no package at all that specifically lists LED tail lights as included. So, as far as tails on a rebel or Laramie, if it’s not possible to equip them with LED tails at all, then it’s not possible to have the animated rear lighting feature.
As far as the headlamps, they are all the same reflector led headlamps from tradesman to rebel. Can anyone with these reflector headlamps tell me if they have signature lighting (what some refer to as “halos”)? The sure way to check this in any ambient lighting situation is to go into the radio settings a turn off the daytime running lights. Turn the headlight switch to the off position, and start the truck. Is there any type of lighting that is on in the headlamps?
Also, @AnthonyRI, can you post up the current rebel and Laramie order guide pdf’s please?
Also, I need to verify, but i'm pretty sure the turn signal marker lights (yellow) are incandescent as well.
