Toperz
Thanks St-na.Error code: B2286
Calibration Not Learned/Lost Calibration
I did same thing what you did with '19-'20 module and everything is good.
Yes 2019Your truck is 2019?
Did you get it to work?Yes 2019
So it kinda works now. I changed it from MY22 to 20 and force calibration on all cameras. That seems to work but the sides are a little off and now my surround button is gone and soft keys dont work. But when I click on rear camera I get the 360 view with lines.Did you get it to work?
What I did is calibrate all cameras separately, when I force it calibrate all cameras its kinda worked. Started with front and went around. After front camera calibration was done I disconnected from CVPM and reconnected then cleared faults and to the next same process. I can not to switch to side view. Just top view/reverse or top view/front or front, back, front wide, back wide. Like on this video:So it kinda works now. I changed it from MY22 to 20 and force calibration on all cameras. That seems to work but the sides are a little off and now my surround button is gone and soft keys dont work. But when I click on rear camera I get the 360 view with lines.
Also, what is the side view suppose to look like? I plugged in my front camera into side view and I could see it all, but when I plug in my side mirror cameras I get a zoomed image on the tires.
Can anyone confirm that 6RN80___AA is the correct part number for a 2019 1500 laramie longhorn tailgate handle needed for wider view camera? My paint code is PWQ, but I can't find anything with that part number provided in original post with my paint code.Remember that you need different tailgate handle as camera is bigger. Also connector is different.
Not sure what you are asking on the BCM wire.What port do i plug the from cvpm wire into the bcm?
What fuze do i tap?
There's a star connector right next to the CVPM. It's a white box with green connectors plugged into it.The wire that jimmy07 makes that goes from the cvpm to the fuze box and the bcm
Am i not using the correct terms?
The only wire thats not a fakra wire
What do the two ends connect to?
One is a fuze and one goes to some port on the bcm i think…
Doesn’t matter which open spot you choosethe cvpm is on the passenger side.
I need the other end by the driver door.
Can i plug into any of these?
Does it matter which one?
Engine doesn't need to be running except for calibration.wires run. Alfa changes made.
Cant seem to connect while engine is running.
Am i using the wrong obd?View attachment 191034
You won't get anything until you calibrate.
This is from the how to in the first post.Yes trying to connect to calibrate and cant connect
Also…using a tazer as a bypass
Alway worked well so far.
How do i connect while running?
To callibrate?
Can’t use a bafx to connect to the CVPM.Yes trying to connect to calibrate and cant connect
To callibrate?
Can anyone point me in the right direction to find the right part number for front camera mount for 2019 1500 Laramie Longhorn? I can’t find a part number for that grille and I’d really like to get started with this project!!After installing the 360 Surroundview Camera System, I decided to put this together to help others. I know there are several others who have done this. If you have any extra input, please let me know. I will start with the parts list first. Make sure to read the notes. You may need to find the correct part number depending on your configuration or color. It was about $1200 using used items. About $2200 new.
Parts List
1 of CVPM - 68318033AI (Uconnect 4) or 56029964AF (UConnect 5)- This goes in the passenger kick panel. It comes with the mounting bracket.
4 of Camera - 68144068AD - It is the same camera. To save money, I bought used mirrors off of eBay and took the cameras out of them. The mirrors don't need to be in good condition.
1 of Driver Side Mirror - 68276511AG - These vary depending on blind spot monitoring, cap colors, and other options. I bought used ones from eBay.
1 of Passenger Side Mirror - 68276510AH - These vary depending on blind spot monitoring, cap colors, and other options. I bought used ones from eBay.
1 of Front Camera RAM Mount - 68341467AC - This could be different depending on the grill you have.
1 of Front Camera Bracket 1 - 68341480AB - Holds the front camera in the RAM mount.
1 of Front Camera Bracket 2 - 68365873AB - Holds the front camera in the RAM mount.
1 of Tailgate Handle - 6RN80GW7AA - This will vary depending on the color and type of tailgate you have. Replace GW7 with your color code that you can find on the placard on the inside of the driver side door.
1 of 68529657AA - Tailgate handle spacer. This holds the camera in the tailgate handle.
1 of 16.5' Fakra Z - Male to Female Amazon.com - Front Camera to CVPM
1 of 10' Fakra Z - Female to Female Amazon.com - Driver Side Mirror to CVPM
2 of 6' Fakra Z - Female to Female Amazon.com - Pass Side Mirror to CVPM, CVPM Output to Radio
1 of 6' Fakra Z - Male to Female Amazon.com - Rear Camera from Radio to CVPM
1 of 3' Fakra Z - Male to Female Amazon.com - Tailgate Camera Adapter
2 of #6 3/8 Stainless Screws - These are needed to install the front camera in the RAM
1 of Front Camera Jumper Harness - 68322480AD - This isn't really necessary, but it allows you to disconnect the camera easier when removing the grill.
1 of Wiring Harness for CVPM - Jimmy07 can make this for you. Just send him a PM.
Surround View Camera System.
Diagram of OEM Surround View Camera System. Contains Module forward facing camera. [surround view for Surround View Camera System. Fits 1500.www.factorychryslerparts.com
Keep in mind that some of the parts listed above need to be researched depending on options on your truck.
The install is pretty simple, but time consuming. I am not going to go into detail on each item. I will give an overview. You can find videos and instructions on removing the items on YouTube and here.
Front Camera:
You need to remove the grill. Once it is removed, you need to remove the RAM letters and replace it with the new one with the camera. Too me, this was the longest part of the build. You can install the jumper harness now too.
Rear Camera:
You need to remove the tailgate handle and replace it with the one with the new camera. And NO, you cannot use the old camera. The new cameras have a wider degree of view. Use the Tailgate Camera Adapter cable in between the factory cable and the new camera.
Driver's side and Passenger side:
Replace the mirrors with the new ones. You will need to install the cameras in the mirrors unless you bought used ones off that already have them installed.
Running the cables:
I ran the front cable down the driver's side and went through one of the firewall rubber gaskets. Make sure to seal it back. I then ran the driver's side mirror and this one together under the dash over to the CVPM. The passenger side doesn't need much running as it is right there. You need to remove the radio. You will unplug the rear camera and plug in the cable to run it to the CVPM. Then plug the other cable into the radio and run it to the CVPM.
CVPM Install:
Remove the passenger side kick panel and install the CVPM. You can hook up all the cables. The CVPM is labeled for the different cameras. Then hookup the wiring harness and run it over to the fuse box. Make sure to plug it into one that comes on with remote start.
AlfaOBD Changes:
You will need an MX+ or switch the cables around. Again, I am not going to go into this as there is information about it already. If you have issues finding the settings, use the search in AlfaOBD.
VehConfig 1: Rear View Camera- NO
VehConfig 2: CHMSL Camera- NO
VehConfig 7: Full Central Vision Processing Present- YES
ECUConfig 3: Rear Camera Present- NO
Radio & Connectivity: Rearview Camera Zoom Buttons Present- YES
Radio & Connectivity: Surround View Camera On/Off Softkey Present- YES
CustSetMenu 1: Rear View Camera Gridlines CSM Present- NOT PRESENT
CustSetMenu 1: Rear Camera CSM Present- NO
CustSetMenu 2: Rear View Camera Delay CSM Present- NO
CustSetMenu 2: Surround View Camera Gridlines CSM Present- YES
CustSetMenu 2: Surround View Camera Delay CSM Present- YES
Cabin Net: CVPM Central vision processing- ENABLE
Once you do this, you should be able to at least see the front and rear cameras in the surround view display. You will now need to calibrate the surround view cameras. This is what you need the MX+ for. Plug in the MX+ using the SGW Bypass. You'll have to calibrate the cameras when you're done. Find an area that you can drive straight at about 4mph for about 400'. Connect to the CVPM in the radio module list. Run the camera calibrations individually for each camera.
Enjoy your new camera system. If you have questions, please post them in here. If I get more time, I will add more details. If anyone has more details to add, let me know and I will add them.
