Guess you didn't quite read everything I posted.
Genius advice....appreciate it
Reading hard.
Math harder.
Another oil change but for the DIYers, Walmart now carries PUP 5W -20 and 5W - 30 for $29.
Theres also a shell $25 rebate for a 10qts or two 5 quart jugs purchase making your cost for two 5qt jugs almost half price.
Very nice!Visited the only standing original bridge of Alaska Highway.
Unfortunately, I was 4 years too late to drive it.
View attachment 189516View attachment 189517
Also, got to the end (or the beginning, if going the other way) of Alaska Highway.
As usual, a lot more in my build thread.
He was making a joke, there’s a lot of that on this forum. Most of the jokes have a basis of truth, so you might consider reading between the lines sometimes.Guess you didn't quite read everything I posted.
Figured that, this forum is no different than the rest of them. I understood his meaning, but as I stated I wasn't putting my foot into it.He was making a joke, there’s a lot of that on this forum. Most of the jokes have a basis of truth, so you might consider reading between the lines sometimes.
Looking at your sig, I’m guessing you have a 26 or 33 gallon tank, and I think we can all safely say that a new muffler won’t cause you to burn 6+ gallons of gas in 30 miles. Is it possible that there was some packing or something inside the muffler that is now causing a restriction?
In all seriousness, I did miss that you were new the forum, and it's annoying when smartasses like me don't just give you the desired answer.Figured that, this forum is no different than the rest of them. I understood his meaning, but as I stated I wasn't putting my foot into it.
I have a 26 gallon, wish I had the 33, but buying used can't always get what you want. I agree with you 100%. However, it doesn't explain the loss in mileage. It's now Tuesday and I'm at a half tank. I purposely since Monday afternoon set the cruise to 75mph to stay somewhat consistent on the highway. At this rate I won't make it until the end of the week on a tank of fuel.
No sir, I checked the muffler and the resonator deletes to make sure they were clear before I installed them. I'm a bit puzzled over it and frustrated, because it doesn't make any sense.
Someone else is enjoying your gas.Figured that, this forum is no different than the rest of them. I understood his meaning, but as I stated I wasn't putting my foot into it.
pictures?Installed 1” spring spacers at the rear end. Installed 2.5” front spacers previously and that netted 2 7/8” which made the truck ride dead level front to rear. 1” rake looks much better.
I did the same after my level, but I went with a 1.5 rear for towing my camper. Completely empty, before the rear spacer, it looked level (or maybe borderline nose high, to me anyway), but when I pulled the camper, it looked awful. I don't mind a touch of rake either.Installed 1” spring spacers at the rear end. Installed 2.5” front spacers previously and that netted 2 7/8” which made the truck ride dead level front to rear. 1” rake looks much better.
I agree on the bags. They're good but can only do so much. And I found that they were kinda fighting me with the camper and wdh. I went round and round trying to find the perfect combination of settings. Now I don't use the bags with the wdh unless I just need a couple pounds to firm things up. I use them only for bed loads, or heavy trailers without the distribution hitch. The best thing I did was go to a heavy duty tire. Towing with the factory ones really sucked.I think I might do this next. Mine does look a little nose high most days.
And when I'm towing.....Lord have mercy!
The airbags in the back do help, but still.....
