Ultimate OBD JScan Thread
No wiring kit. It's a live feature of the TazerDT. Meaning it has to stay plugged in
I was thinking of this. If that’s all you want to do, it would save you a couple hundred bucks
Awesome info here! I just adjusted my tire size and fog light drop off.
I keep reading where some of you reset ecu's etc. How important and why?
Thanks, Greg
Thanks, Greg
As I understand it, which isn't saying much, I think it's like when your computer glitches and you reboot it to "reset" it. The Alpha reset is much the same. If the process you are trying won't "start" or whatever, a "Reset" may be in order.
Hopefully, Jimmy or someone can confirm this or clarify it
Thanks, Greg
If you’re changes don’t take, sometimes a reset of the particular module will be needed
Programmed the "Tailgate open" alert on my 2200 Big Horn after installing the correct hardware. Could not have been easier.
Adaption> search for Ajar> Tailgate Ajar Indication.
Change from "Deactivated" to "Activate"
Adaption> search for Ajar> Trunk Ajar Signal Input Present- On/Off
Change from "Deactivated" to "Active"
Not sure if I asked this already….since I have the signals as DRL, can I make them stay on with the headlights? Maybe this?
No. DRL dropout means you want the DRL lamp to shut off (drop out) when the turn signal is used- example: if the DRLs are the low beams, and you activate the left turn signal, the left low beam drl will shut off while the turn signal is blinking.
Since your turn signal lamps ARE the DRLs, this setting would be irrelevant to you.
That makes sense. Thanks @Jimmy07
If you disconnect your battery for a few secondsz it resets this as well. Which is why most people say they get better throttle response after installing a cold air intake. Since they disconnect the battery when they install it
I see. Thanks. I wonder why they have this procedure then.
Has anyone tried this to see if it helps throttle lag?
This procedure doesn’t do anything for throttle lag, and disconnecting the battery doesn’t do the same thing. I had to perform this procedure when I swapped in adjustable pedals for my non-adjustable pedals.
Thanks @Jimmy07
Anyone know what this does?
I’m new to JScan just put in for tailgate ajar and module does anything else has to be done for it to show up still don’t see it on radio
Also in what area in settings in the radio will I find it
I dont know that it does show up on the radio. I will have to look. Mine just shows up in the center EVIC.
Did you make the same changes I posted above?
