See a o
See my post above, don’t bother wasting your time lol.
stevo you are 100% correct. the anc is built into the amp which is controlled by the 4 microphones in the cabin. Now this is what i was alluding to in my previous post. the 8 wires (front right and left + and - along with rear right and left + and -) feeding the signa;l to the stock amp might not be high level. i planed on pulling the input wires from the stock amp this weekend and oscoping them to see what kind of signal is feeding the amp. an electrical engineer buddy of mine claims it is a low level 5vrms signal. he claims that the pac unit just piggy backs the low level signal output coming out of the radio at the radio harness then sends it to there dsp/eq unit. now if your just adding a sub i would say piggybacking to the amps input would work the best because ur by passing the anc only for the sub. the only problem with doing it for the whole system would be chimes, anc and other audio related functions the truck has that probably runs thu the canbus to the factory amp. hopefully the weather cooperates this weekend and i can test the amp inputs to see really what is going on in the signal path.,
