nemecham
Here is stock without the fitcamx
And with…
And with…
The mount won't work with that. The comma works as a dashcam so I don't see a reason for another one. I think you will find issues with the two working together unless you move the FitcamX someplace else.Here is stock without the fitcamx
And with…
That is true. It doesn't record audio, just video. There are other limitations too. It doesn't overlay speed or GPS. That has been requested though. Not sure when or if it will be integrated.That’s fine. I’d probably just remove the fitcamx as it is a whole replacement for the stock bezel. I read that the C3 acts as a dash cam, but doesn’t record audio. Is that true? I’ll send you a PM for the mount.
Tons of time mine just fails to record footage too. I don't trust my Comma3 to work during an accident.That is true. It doesn't record audio, just video. There are other limitations too. It doesn't overlay speed or GPS. That has been requested though. Not sure when or if it will be integrated.
Garbage product? Mine works great and always has. As do many, many others. Sure, there are some minor issues, but you seem to be the exception. Of course, I'm only going by what I see on all 3 Discord servers.Tons of time mine just fails to record footage too. I don't trust my Comma3 to work during an accident.
Support also will not fix it after 8 months of emails.
On paper it should be more reliable then the Fitcam but in practice not so much.
With comma prime you can get side by side gps and video, which is similar to my older dash cam, but again the Comma 3 doesn't provide gps data for 80% of my trips and Comma support said that is normal for gps to not connect for the first 45 minutes of a trip (eyeroll).
The comma is a garbage product in a locked ecosystem only kept alive by 3rd party developers with 0 support including hardware problems.
I might be the exception but after months of back and forth Comma will not stand behind their product or offer any assistance. I have had hardware problems within 2 months of buying it.Garbage product? Mine works great and always has. As do many, many others. Sure, there are some minor issues, but you seem to be the exception. Of course, I'm only going by what I see on all 3 Discord servers.
R u going over 32 mph?I just got had my Comma3x delivered/installed today and went through the setup. For whatever reason, I cannot figure out how to get the unit to engage. I enable and set ACC, but the unit never kicks in. I have tried to find info on how to start my first drive online, but am only able to find installation instructions and drive reviews - nothing about initiating the first drive. Looking for any sort of helpful tips to get started. I have already paired the device with my phone and set my home address within the webpage. This is the only screen I can see on the Comma3x device, in addition to the settings.
Yes, I had cruise set for 35mph for a brief 10 - 15 seconds or so. The unit never changed from the screen in the picture.R u going over 32 mph?
Sent from my SM-S918U1 using Tapatalk
More information on your truck would help, year and model. So, the Comma doesn't show video of the road from its front camera? You can get faster help from the Ram OpenPilot discord server. Join the Ram OpenPilot Community Discord Server!I just got had my Comma3x delivered/installed today and went through the setup. For whatever reason, I cannot figure out how to get the unit to engage. I enable and set ACC, but the unit never kicks in. I have tried to find info on how to start my first drive online, but am only able to find installation instructions and drive reviews - nothing about initiating the first drive. Looking for any sort of helpful tips to get started. I have already paired the device with my phone and set my home address within the webpage. This is the only screen I can see on the Comma3x device, in addition to the settings.
Hmmm. Should've turned to screen showing the road. Suggest unplugging the OBD for a few minutes then plug back in for a good hard resetYes, I had cruise set for 35mph for a brief 10 - 15 seconds or so. The unit never changed from the screen in the picture.
And that screen comes up before you even start driving.Hmmm. Should've turned to screen showing the road. Suggest unplugging the OBD for a few minutes then plug back in for a good hard reset
Heh, sorry. It's a 2021 Ram 1500 Limited with eTorque. And you are correct. I never see video of the road from it's front camera.More information on your truck would help, year and model. So, the Comma doesn't show video of the road from its front camera? You can get faster help from the Ram OpenPilot discord server. Join the Ram OpenPilot Community Discord Server!
Turn off experimental mode. Doesn't work on the Ram.Heh, sorry. It's a 2021 Ram 1500 Limited with eTorque. Thanks for the link. I'll join the server soon.
I tried both experimental and Chill mode, but good to know.Turn off experimental mode. Doesn't work on the Ram.
Do a reset and try the install again. You should see video from the comma's front canara. It's not initializing the camera. Could be a bad install.I tried both experimental and Chill mode, but good to know.
Will do. I'll give that a try and will report back soon. ThanksDo a reset and try the install again. You should see video from the comma's front canara. It's not initializing the camera. Could be a bad install.
