StuartV
Ok Im an old retard but what in the hell are battery powered “underwater scooters”?
This is one:
Genesis 3.1 | Logic Dive Gear
logicdivegear.com
Me in action with one of mine:
Honest question:
Have you read ANY information on how the generator in the ramcharger is designed to function?
Is this not true from Caranddriver for example? It's ultra clear to me.Yes, but I have found documents that 100% conflict with each other, and lots that have sales lingo crap which doesn't make sense.
Ain’t that the truth. The defects and recalls are going to be rough, as with any new tech.Peeps better get a 7 year Max 0 deductible Mopar warranty with that drivetrain. Can you imagine the cost to repair?
Will the techs even know what to do the first year (2025)?
Remember the forum posts on the early adopters 48v mild hybrid battery pack issues? Yep they have mostly been worked through by now but there was a lot of anxiety and frustration in forum posts back a few years.
I can only imagine what the early adopters will go through with this new drivetrain complexity.
My first year 2015 aluminum bed F150 caused body shops lots of issues due to not being trained up/certified on aluminum. Repair costs went up, insurance costs increased… Nothing like what‘s happening with the EV’s though.
It will all get worked out.
EVs use chargers that are powered by energy created by coal, so is that also an EV?
The Ram charger is a hybrid. It has an regular old engine in it. You can call it a generator if you like but it's literally an 3.6 pentastar. Lip stick on a pig... Still a pig.
It does have electric motors so it's a new kind of hybrid is all.
It can't make the wheels move by the ice engine alone as it only had electric motors. You take the battery out of the ram charger and you can no longer move an inch without getting out and pushing it no matter how much gas you throw into the secondary engine as it can't be used to charge the battery so the electric motors can go.
Well, it’s actually very simple.Yes, but I have found documents that 100% conflict with each other, and lots that have sales lingo crap which doesn't make sense.
We know the v6 can power the motors directly, but will the programming allow this without the batteries installed? Idk. The dash might say “battery pack not detected, see dealer” or something, and not run.
Some states are already charging an EV tax on registration.Interested in the RamCharger but disillusioned as well. When doing simple math dividing Battery mileage by Battery capacity, the RamCharger is quite a bit less efficient than the REV. It's electrical power consumption is more aligned with a Hummer than a REV or even a Silverado. I hope the initial estimates are wrong.
I'm also still waiting to see how the states are going to recover road taxes normally part of gasoline prices. During annual registration, will it be a charge on a per pound basis * some mileage factor or simply a percentage of the new vehicle cost each year? If one can afford an EV, then should one have to pay more than their previous taxes for road upkeep?
Socialism at it's finest. Legislate the market to get people to buy something then tax the devil out of them for buying it.
The Ramcharger has a smaller battery pack than a full EV. So the range in battery will be less. And efficiency will be lower due to smaller batter, but heavier weight due to the ICE and generatorInterested in the RamCharger but disillusioned as well. When doing simple math dividing Battery mileage by Battery capacity, the RamCharger is quite a bit less efficient than the REV. It's electrical power consumption is more aligned with a Hummer than a REV or even a Silverado. I hope the initial estimates are wrong.
I was hoping the weight of the engine/generator would be offset by the weight of a smaller battery. If it balanced out, then the battery efficiency should be the same as the REV assuming it's using the same voltage EDM. Even if it didn't balance, I have a hard time believing the increased weight as a fraction of total vehicle weight justifies a 25% drop in efficiency when operating on battery alone.The Ramcharger has a smaller battery pack than a full EV. So the range in battery will be less. And efficiency will be lower due to smaller batter, but heavier weight due to the ICE and generator
Electrical efficiency between the Rev and the Ramcharger isn't even on my radar. The whole point of the Ramcharger is that it has a gasoline powered generator to extend the range far beyond what you can get from the Rev. The two vehicles are meant for different types of buyers. Those who are okay with a truck that's 100 percent dependent on plugging in to charge, and those who are not. The 150 mile battery range of the Ramcharger is more than enough for my daily commutes. Charge overnight and repeat. I would only need to use gasoline on the weekends when we tend to drive quite a bit more.Interested in the RamCharger but disillusioned as well. When doing simple math dividing Battery mileage by Battery capacity, the RamCharger is quite a bit less efficient than the REV. It's electrical power consumption is more aligned with a Hummer than a REV or even a Silverado. I hope the initial estimates are wrong.
My assumption is like the Silverado, early cost estimates on both (REV & Charger) are lower than what the vehicle will be introduced for. Since a loaded gas Limited can go in the 80's I expect the EV's to be at least 10K more and the Tungston group to drive it over 100K just like the Silverado. A lot of affordable hype up front followed by updated pricing taking out of most peoples budget. If I go this route it's my retirement present (a couple of years early). I just have to be sure it won't quickly become a boat anchor since its a first year vehicle. I've never leased a car, but this might be the first time so I know what my walk away costs will be if the truck is problem ridden.Exactly. I won't even consider the Rev, never going to happen this decade and probably not next either.
The Ramcharger though, that all depends on cost.
Based upon the fuel tank and expected range from it, when running from the generator fuel economy is probably no better than a Hurricane based 1500. So the question I am looking at is the extra cost for the electric side justified over the life of the vehicle. This is where looking at the Miles/KWH and cost/KWH come into play. It's probably like getting a $1.00 per gallon savings by using electric instead of Gas and paying for that up front. Ignoring cost of capital and assuming the truck costs $10K more than an equivalent hurricane that's the equivalent of 10,000 gallons of fuel to get a payback. At 20 MPG it seems to take 200,000 miles compared to maybe 150,000 miles on a REV.Electrical efficiency between the Rev and the Ramcharger isn't even on my radar. The whole point of the Ramcharger is that it has a gasoline powered generator to extend the range far beyond what you can get from the Rev. The two vehicles are meant for different types of buyers. Those who are okay with a truck that's 100 percent dependent on plugging in to charge, and those who are not. The 150 mile battery range of the Ramcharger is more than enough for my daily commutes. Charge overnight and repeat. I would only need to use gasoline on the weekends when we tend to drive quite a bit more.
You can't really look at the fuel milage as only the range specified for fuel alone, but total range when driving. Since most will never drive it far enough on a daily basis to ever need to use the ICE for power, you greatly extend the miles before you need to fill the gas tank. So you don't need to drive 200k miles to get the savings if you only have to fill the tank 2-3 times a year with normal daily drivingBased upon the fuel tank and expected range from it, when running from the generator fuel economy is probably no better than a Hurricane based 1500. So the question I am looking at is the extra cost for the electric side justified over the life of the vehicle. This is where looking at the Miles/KWH and cost/KWH come into play. It's probably like getting a $1.00 per gallon savings by using electric instead of Gas and paying for that up front. Ignoring cost of capital and assuming the truck costs $10K more than an equivalent hurricane that's the equivalent of 10,000 gallons of fuel to get a payback. At 20 MPG it seems to take 200,000 miles compared to maybe 150,000 miles on a REV.
The only way an EV with low Miles/KW makes sense is really bragging rights since the MPG (gas) isn't any better than a gas 1500.
That said, I added an 8KW solar array to my house (in Michigan) about years ago. The only real justification was the Tax and Utility credits. It really hasn't saved me any money since the utility changed the rate they pay for excess solar during the day (when I'm not home and can't use it). It gives bragging rights, but doesn't really save any costs.
Do I want to have bragging rights, Yes.
Do I need more than 150 miles per day in my current job? No
Do I want a truck which can pull a trailer or take a 200 Mile trip? Yes
Do I really want to spend $100K+ on a vehicle with a limited life span two years before I retire, I'm not sure.
Do I think any EV will power my house in a power outage: Not really, I currently use a 15KW generator connected to the PTO of my tractor. 7.2 KW is lame and the V6/Genset can do so much more
