PR40.1 Update File?
Bin01123
Atlanta, GA
If you are trying to jump from an early release to newest it will happen. Need to step up through the revisions,
I'm currently on version 39.2 and am trying to update to 40.1. Hopefully I'm not skipping a version
That should be fine but there is a 39.7. You may also want to verify the file you downloaded to make sure it's not corrupt and you have it loaded in the thing drive properly
Bin01123
Atlanta, GA
I’ve download that file from multiple sources. Tried different thumb drives and still the same issue. I wouldn’t mind trying 39.7 if I find it.
Vivrosh
Is there is any way? We can update the map data. I update to 40.1 successfully and its a software.
do I have to pay for the map?
azzx
Central AZ
Yes - you have to pay for the map - 40.1 has nothing to do with the map update
SandmanMV
I downloaded the 40.1 update. Had 34.31. Took 3 different USB sticks until I found 1 the Ram liked. After that there were no issues.
MrRathman
So I have 34.31....
I have a freshly formatted (not quick format) FAT32 to 4096 bytes (unit size) 4GB flash drive. Followed all of the instructions to a T (extract, not copy, 39.9 version)
Tried 3 different flash drives all formatted the same.
Still getting hung on 19% and failing.
Not sure what is the issue
So I have 34.31....
You can't go from 34.31 to 39.9. need to start with a lower version and work your way up
MrRathman
Where can i find the lower versions?
I thought i read on the TSB that if its at least 34.2 and under 39.9 then you update to 39.9...... thats under step 2 on the TSB.
Not sure, just a suggestion as I've seen others havi g issues trying to make the jump to newer updates
MrRathman
is there a link to the 39.7... ill certainly try it.
I haven't seen one a link
Bin01123
Atlanta, GA
So I have 34.31....
I had the same problem. I have the truck at the dealership now for a separate issue and I’ve asked them to address this as well. We’ll see how they make out
Try this. Scroll down to bottom of the Google docs fokder for other versions
MrRathman
so i did find a link to 39.6... ill try that as soon as this extract completes on this usb.
Scrath that... it was a UAQ 39.6. WIsh i could find the 39.7... this link is broken
Appreciate the assist here guys!
jerwintexas
Does this update (or any update) provide functionality for Wireless Car Play? Have 2021 RAM.
Thanks
