Scram1500
- Jan 15, 2020
Captain Tolley's worked for me. Had a small leak in the upper corner of my replacement window on the drivers side. It would only leak during major downpours. I pulled off the interior trim and could see a droplet form where the glue met the frame.
At any rate I put this milky stuff into a syringe and from the inside of the cab applied small drops to the spot where it was leaking. Capillary action sucked up the glue immediately. After allowing to dry and 2 or 3 more applications there wasn't anymore capillary action.
Homepage
Penetrating sealant for repairing leaks from hairline cracks in the home, RV, car and boat. Dependable since 1986. - Find and Fix Leaks from Hairline Cracks -
captaintolley.com
