ferraiolo1
North Central PA
Washed her off from riding up dirtbike trails yesterday. Oddly this is the latest in the season summer wheels have stayed on.
JOzzz
Can you post pics of how you attached them to the truck. None of the holes one mine meet up with the factory mounting points. It almost seems like I will need to drill new spots to attach them?
I can take a pic tomorrow but I used the holes that were already there on the flaps and the factory screw holes. I started with the top one, then worked my way down.
1.21gigawatts
7-Stringer
Boston, MA
I just got the OTA Update notice a few weeks ago. I pressed okay. It happened. No issues. Never noticed anything different.
so do you know what software version you went from/to for this update? i actually had an OTA update come in like a couple weeks before even getting this notice in the mail... so now i'm wondering if its already been done haha.
1.21gigawatts
7-Stringer
Boston, MA
Yep, a lot quieter and smoother. I had a set of DuraTracs and my buddy has the Wildpeaks. The only negative for me with the Wildpeaks, is they aren't very aggressive looking. If they would beef up the sidewall lugs, I would buy a set.
I agree... i also like the chunky rim protector on the duratracs and there aren't many other tires with that. The Nitto Ridge Graps have a good one but the one on the wildpeaks is pretty small. And for me it's not about like curb rash protection like it is on cars... for ATs it more prevents something from wedging in betwixt the rim and tire. plus i like how it looks. But of the lesser aggressive ATs i think the Wildpeaks still look pretty good and i've yet to hear someone not like them.
Dogpatch
Coldstream, BC
It just showed up on my screen. I hit okay but was a bit worried cause I had to shut the truck off for an appt. before it was done. I came back and it showed update complete when I started the truck.
I never received a mail notice.
JamRam
I had to start the truck manually this morning....again!
It has happened 3 times now where I try start the truck from inside the house, the truck acknowledges the signal (honks twice), tries to start but doesn't....makes the sound like the battery is dead.
When I go out, the dashboard reads "Remote start disabled. Start manually to reset".
Hit the brake, push the start button and it starts right up...everytime. No CEL or anything. Its not even that cold as we are still in negative single digits.
What's up with that?:unsure:
Eighty
Moderator / Dream Killer
Do any of these conditions apply? If so, remote start won't work.
JamRam
Perhaps the only one that I cannot vouch for is the Battery charge. The truck is only 2 years old but I guess the OEM battery isn't meant to last too long.
BUT.....if the battery charge was low, wouldn't there be an issue with starting up manually as well?
CHeYeNNe71
It's more of a safety, so if your vehicle doesn't hit certain parameters, it won't use RS. Just like with a CEL, your vehicle will start when you push the button, but RS won't work.
Dogpatch
Coldstream, BC
Could it be a low fuel shutoff? My diesel RV was like that. 1/4 tank and generator wouldn’t start. Fail/safe. Just thinking outside the box.
HEMIJAKE
Potter County, Pa
I will confirm if you're at the "50 miles to empty" or whatever warning on the dash, remote start does not work. It will start, but not continue to run. That's usually how I remember I have to get gas that day :LOL:
JOzzz
boogielander
Sick!
Do they go back far enough to cover the cats? I can’t tell.
here is all the info you need/ want regarding the skid plate package. I did a complete overview and review of it a while back.
Dogpatch
Coldstream, BC
Got the new “Winter Meats” put on the Limited. Yokohama IceGuard G075 in a 275/55R20. 4.9 outta 5 rating from what I’ve seen.
Not the Hakkapeliitta R5’s I wanted, but also didn’t have to pay an additional $800 to get them.
I’ll give these a try this winter. Should be good for 🇨🇦.
Ya I know, the rims are Longhorn rims, truck came used with them but saved them for my winter tire swap out set.
  • Axe
