- Apr 11, 2019
There’s a rear antenna, part number also in post 7, and the need to use AlfaOBD to enable the feature (Jscan also works if you are strictly an iPhone user).well this thread hes evolved into a 50 page monster, with a lot of info!! Been thru most pages, but still want to make sure I have things correct….. just so much!!..
I have a 2021 olive green Laramie WITH passive entry on the front doors….In order to add passive entry to the rear doors as well, I would need to order: 2 passenger front door handles with 2 passenger door caps, part numbers in post #7… chrome and green for me.. order a couple of pre made harnesses from Jim. And follow the directions in this tread, what involves tying into some wires in the front door sill… this all sounds about right?? just want to make sure I am not missing something…. Most of this thread is about adding PE if you do not have it at all,just want to make sure it is as easy as adding some parts to get it to work on the rear as well if you already have it on the front..
Pete
