RedRaider91
- Jan 23, 2021
I need the passenger side haha. Unfortunately I can’t find them anywhere. I guess I can order and just wait but with the strikes going on I’m sure no one is makin any
The pics you posted have a different part number than the links provided. Can you clarify?I purchased the latest OEM manifolds and found a few design differences from the ones that came on my 2019.
Time will tell if the changes will improve longevity but I felt that $67 and a couple hours of my time was better than spending $800-$1200.
I ordered from here and got them in less than a month. They are not currently showing as backordered so you may get them sooner.
2019-2024 Mopar Exhaust Manifold Kit 68591572AB | All Mopar Parts
2019-2024 Mopar part # 68591572AB - Exhaust Manifold Kitparts.allmoparparts.com
2019-2024 Mopar Exhaust Manifold Kit 68591573AB | All Mopar Parts
2019-2024 Mopar part # 68591573AB - Exhaust Manifold Kitparts.allmoparparts.com
Here's the changes made to the casting in the areas that typically crack.
View attachment 168739 View attachment 168741
I see the same thing. I had my eye on AFE, but many users have reported broken welds after some time using these.I was eyeballing the BBK Headers as well. Even new, they aren’t that expensive. There are mixed reviews on how well they stay sealed but using specific gaskets seemed to be a very common theme to good results with any header installation. Remflex I believe is the name of the gaskets.
The links I posted are for the complete kit. The manifold is just one component within the kit.The pics you posted have a different part number than the links provided. Can you clarify?
Good to know!!I drove mine for the last year or so and I survived.
Anyone know what the actual issue is? Engine is the same, right? Does it hit body or frame somewhere? Something a big friendly hammer would fix? Sawzall?
@Cbty2050 can maybe help?Anyone know what the actual issue is? Engine is the same, right? Does it hit body or frame somewhere? Something a big friendly hammer would fix? Sawzall?
I honestly haven't seen much of a difference, they will bolt up but really don't think there is much of a difference. If I recall the ears for the ypipe may be turned different but I doubt that will be an issue.@Cbty2050 can maybe help?
When did it say it was backorder? after you pay?Well just my luck, once you add them to your cart they’re on back order.
Do you know when the new AB part is being added to new built trucks? More specifically is it on the 2024's?I purchased the latest OEM manifolds and found a few design differences from the ones that came on my 2019.
I would imagine, as soon as there is a new design, they run them on the line. But that only makes sense, so no guarantee. Engines aren't built very long before they are used. Only way to tell, is look at them when the truck comes in.Do you know when the new AB part is being added to new built trucks? More specifically is it on the 2024's?
Only manifolds that crack are the ones with the tie bars.I ordered the AB kit from All Mopar parts on the 8th (two days ago) it arrived today. View attachment 169038
$65.67 plus shipping.
My manifold seems fine, has at least two broken bolts tho.
WHAT!Only manifolds that crack are the ones with the tie bars.
And without it the bolts breakOnly manifolds that crack are the ones with the tie bars.
Yup, its cheaper to buy the updated by far.And without it the bolts break
