How was the install?
Super easy. 2nd one was like 10 mins after I figured everything out with the 1st one that took maybe 30mins.
I still have to line up the beams. But you can tighten the brackets enough so that you can adjust up and down with some pressure.
I like it I am wanting to do something similar found some that you can do white led + amber as well I was thinking about doing.
Saw those. There’s some switchback bulbs now too. Went with these because of the rep with the taco and subi dudes. They were also on sale during the 15% off promo time.
Love my panoramic sunroof, but today found one of the flaws with it. It shudders when closing. I tried lubricating it and still did it. Took it to dealer today to get diagnosed. They tried lubricating as well and still did it. Next step is replacing the roof. The sunroof itself is not serviceable other than replacing motors or lubricating. The roof assembly is on national backorder. So will be driving it until new parts come in. Then will be going to body shop for major surgery. I haven't had an issue with rear window leaking, and hope this doesn't induce it as they have to remove the front and rear windows to do the work
Sitting at my local dealer now waiting for them to finish with the PCM update for the 2021 eTorque recall.
Hello,
Please keep us updated on your repair after the vehicle has been serviced, as your feedback is important to us. Thank you
William
Ram Cares
Had recall 37A for PCM done this morning. Not a jumpy as it was when moving from a complete stop. So far so good.
Thank you for your feedback on this. Please let us know if you run into any issues after this recall.
William
Ram Cares
Try this: 3-IN-ONE® Lock Dry Lube
It has fixed multiple issues where water and other oils cause drag.
Here’s my simple NOCO Battery Tender install. I attached the NOCO holding bracket to the fuse box cover so I can view the LED by peering in between the latched (but partially open) hood and the left front fender while the NOCO is plugged in to an extension cord. The NOCO’s cord is not very long, but it is long enough to hang out the front of the engine bay and can easily be tucked back under the hood when not in use. It’s the same setup I had on my Jeep. It works.NOCO1.jpg
Hello,
William
Ram Cares
Interesting, is this for any lag or stalling? I've resigned myself to simply pushing the pedal most of the way down and spinning the rear tires to get it moving when it lags/stalls around a corner. I guess I'll use the excuse of light rear truck if I get pulled over. Had a Durango loaner for a warranty issue before that didn't have this issue, so I know they can program correctly if they want to.
This sounds like a real problem, I have never noticed anything like this in my truck. Have you taken it in to a dealer?
It's probably just the transmission hunting for a gear. My guess is he didnt come to a complete stop and the transmission hadn't fully downshifted before he started to accelerate again. I have noticed it a few times with my truck, and almost a daily occurrence in my work van.
Occasionally yes, stuck in 3rd rolling a country stop sign, but just as much waiting any length of time for a right turn on red in city traffic, the truck will not respond. I've pumped the pedal, and slowly pressed most of the way down, now just 1/3 pedal to start, and add more steadily till I get a reaction. I called it Heart Stopping Lag in another thread. Most likely EPA mandated, or Tradesman anti spin "feature", which don't laugh, but my last GMC had that. Waiting to get out of warranty to get it actually fixed by Greene or Hemifever.
If it's doing that from a complete stop, it sounds like a torque converter issue with the transmission. I'd definitely get it checked out under warranty. A tune isn't going to fix that
Sorry, didn't read close enough what you said a minute ago. No "engine" response from complete stop.
It finally got above 50degrees so that I could apply the vinyl overlays from Reflective Concepts. I never liked the monotone dark look of my truck. These overlays compliment the blue “etorque” badge in the hood. It looks fantastic. Customer service was also outstanding. What I didn’t expect but appreciated is that they send duplicates in case you make a mistake. In the end, I had two letters that needed to be replaced and luckily they sent those extras.
There are two pictures where you can see the contrast as I was adding the vinyl overlays to the badges.
View attachment 157498View attachment 157499View attachment 157501View attachment 157502View attachment 157503
which blue is this, mopar blue?
Great question since I ordered the wrong one initially. They told me, and I can confirm, that "Medium Blue Metallic (B5)" is a very close match to what came on the trucks. I did not order letters to go on the 1500 badge in the hood, because I was concerned that the colors wouldn't be a close enough match. Now that I've got them on there, I will probably order the 1500 overlays as well.
  • pcar
