The rear Bilstein shocks are not adjustable. They are just said to work for 0-2" of lift. The stock shocks aren't designed for lift.So, they say adjustable you just can’t adjust them in the back? Okay I’ll add the Icon 1.5” Springs as well thanks!
Okay thanks for the clarification I swear I have it now lolThe rear Bilstein shocks are not adjustable. They are just said to work for 0-2" of lift. The stock shocks aren't designed for lift.
I will but it’s going to be a couple of months before I get it all installed. Have a lot going on with work and what not.Post pics after
Sent from my SM-G781U1 using Tapatalk
Best set up really depends on your budget and useage. Personally, I say Bilstien 5100s for front level. And you really don't want it to have zero rake. Otherwise it will actually look nose high at certain angles.Bumping this back to the top. Hoping for advise.
Clip 5 is a good start. Clip 6 will make you almost perfectly level.What hight do you recommend? I don't like the front end looking higher, but not so low it looks like a 2 wheel drive.
Just swap over your factory springs. If you don't, you will need to buy the springs as well as the top hat and all the hardware to install the springs to the struts.Looking up the Bilstien 5100, they do not come with the Coil springs. The video mentioned you can use OE springs but recommend separate purchase of light, medium or heavy tuned springs. What is the opinion on OE vrs one of theirs, I'd imagine just the light duty would work for me, I only tow and no off roading.
There wasn't even an option for Bilstien springs a couple years ago. I can't say I have ever heard of anyone complain about the ride using the stock springsI saw that, however there was mention the OE springs are tuned for the OE setup and may experience a different quality in ride. My question is, is it negilable in performance to worry about the extra cost for the Bilstiens springs and just use the OE springs? Obviously its cheaper to use the OE, but will it stiffen the ride?
Suspensionlifts.com sells a kit that comes with bilstein 5100 front struts, 5100 rear shocks and 1 inch rear lift springs. That’s what I used with the front struts set to the highest setting (2.7”) and I used the skyjacker UCAs. Rear is about 1/2” higher. As already mentioned, with your towing, the hellwig rear sway bar and air bags for the rear springs would be a good idea. As for tire size, I have falken wildpeak 285/65r20 on stock rims, no rubbing at all.
I could have, but it's far easier to add a rear spacers than to remove the 5100s to change clip position, and then have to get another alignment doneAssuming you're not picky about getting max ride height, could you have just adjusted the front 5100's down a notch or two and skipped the added rear spacer?
Fair Point. Just thinking out loud, trying to plan my build. Thanks!I could have, but it's far easier to add a rear spacers than to remove the 5100s to change clip position, and then have to get another alignment done
