Best speedometer recalibration tool
Idahoktm
North Idaho
Thanks - I suppose it helps if I update my sig to include my particulars too in case that matters. White 2020 Ram Crew Cab 4x4, Lone Star Night Edition w/ 12” UConnect
It definitely helps, but you don't have a signature. 😁
joshsouth12
Fixed! Copy/pasted yours and removed the mods - unfortunately I’m a couple years behind and just getting around to doing anything to mine (new shoes started all of it) and now I’m looking at a level or small lift, 35s, and basically anything else I’ve found on this site 😂
610SRTGang
Allentown, PA
So I just called my dealer, and he swears that you can’t re-calibrate after 2017 year model. What statement, phrase, or document do I need to send him so that he understands? Or should I just avoid this dealership altogether so they don’t screw it up?
Tell them to go into dealerconnect, hit the service tab, then click single vin inquiry, put in your vin# and mileage on the truck, Then service contract offers.
He will see a list of all the tire sizes they will let you calibrate for.
Birdman_2000
I called my local dealer and they will do it for $135. Looks like buying the tools to do it is more than that. Probably the route I will go.
Tcollado512
Just installed 35x12.5 Nitto Ridge Grapplers on factory 20s (NO SPACERS - NO RUB) and a 2” MotoFab front leveling kit. This is a 2020 Laramie with no park assist. Just ordered speedo calibrator from Rough Country (Speedometer Calibrator | Inline | Ram 1500 (18-22)/2500 (19-21) 2WD/4WD) thanks to this thread. Fingers crossed to me! Lol. I’ll keep you all posted.
Jeffjad
Southwest PA
Looks good. They have to be super close to the upper control arm with no spacer, I would check the inside of the tire from time to time.
Tcollado512
Jeffjad
Southwest PA
Lol...yeah figured it would be pretty close but you may be ok. I loved those tires BTW, I got 45k out of mine, I just couldn't bring myself to pay the current price which is why I went with the Klever's.
drew7777
Richmond, VA
I believe it only deactivates ParkSense if your tires are bigger than 35". I have 33" tires and my ParkSense still works.
Can anyone confirm the above? Called my dealer and they also said it would kill ParkSense (my new tires are 33.5"). I also want to confirm dealer update will adjust shift points and not just fix the speedo?
Morenar
West Central Florida
I have seen many people here go above 35 and the parksense does not work. I can confirm that by updating the tire size will correct the speedometer and the shift points. I had mine done a the local RAM dealer. I stayed under the 35 as my tires were 285/55/22 and my parksense works.
Fixing the speedo does effect shift points as it's correcting the speedo input for TCM.
And I have mine set to 34.7 through the TazerDT and no issues with park sense.
