Roddog2220
Profile Pic![]()
so that's just the readylift 3.5 on 35s? nothing else? front looks lower to me than mine, maybe I need glasses, looks perfect
Profile Pic![]()
Profile Pic![]()
Oh yes, I'm sure you'll settle a bit.Makes sense. I am at about 450 miles.
Nothing else. I think the big difference between ours is that in our side profile pics your nose is at the top of the grade and mine is at the bottom. Probably makes it appear more level.
what was your gas mileage diff after lift and or tires?
Does your truck have the off-road package? I don’t see the decals but you may have removed them if you didn’t like the look.
Neither kit will work. The Readylift would put you at 4.5" of lift and is the reason some people are having trouble. You could add the Mopar lift, but it would only net you 1" of lift because it would replace the offroad shocks. You could order the Readylift 3.5" kit and use everything but the preload spaer. That would net you 2" front and back on top of the 1" from the offroad package, but you would still have the factory rake. The other option would be just to level the front of the truck and leave the rear as is.Hi. I am currently building my try k at the dealership and want to add the readylift to my truck once it’s built. Dealer won’t do it. But my question is will the readylift kit still work if I have the “off road package” which lifts the truck 1” via HD shocks? Would this put me at 4.5”? Which would obviously not work. I really want to add the mopar 2” lift instead so I get the fox shocks. But again will that 2” mopar not work in conjunction with the readylift 3.5”? Thank you for your help
That actually helps a lot. Thank you. One last question if you don’t mind. I’ve noticed on eBay I can get spacers anywhere from 1/2” - 2”. Can I do the mopar 2” kit and add a 1-1/2” spacer to equal 3.5 like the readylift?
I’m starting to think I should just get a plain Laramie either 2wd or 4wd and just use the readylift or rough country 3.5 and call it a day. I’m sure in the future I can get bilsteins or some other superior shock to replace the stock ones. The idea of using a factory lift like the Offroad package or mopar lift seems to be kind of a hassle to try and stretch it to the full 3.5” max.
Either that or go with the 2wd and get a CST 4.5” lift spindle. Sounds like that’s the easiest and cheapest way to get a aggressive stance to clear 35” tires.
For the RLS 3.5" Kit?Can someone please send a long to the kit, I wanna make sure I’m looking at the right stuff...thanks ahead of time
Yes please
