bigdodge
Happy Ram Owner
light on dashHow do you determine if you have the tailgate ajar sensor ?
leave it open and start truck
I think he means, how do you know if you have the sensor (but it's disabled, and just needs to be enabled with AlfaOBD).light on dash
Not all tailgates come with the right-side latch with the limit switch if the feature wasn't OEM-enabled.I think he means, how do you know if you have the sensor (but it's disabled, and just needs to be enabled with AlfaOBD).
what trim does have the ajar sensor working from factory? does someone knows? wondering if my laramie has it (since im injured and can barelly move around i cant go check if i have that)Not all Rams have the sensor in the tailgate that sends the ajar signal. I agree that Ram should enable this feature on all trucks with the sensor.
My Limited worked from the factorywhat trim does have the ajar sensor working from factory? does someone knows? wondering if my laramie has it (since im injured and can barelly move around i cant go check if i have that)
just did, doesnt seem to be there, so i guess my laramie did not came with itCheck your build sheet for tailgate ajar warning lamp.
is it part of the bed light kit(the thread is about that)? if yes i have thatThis thread lists the part #'s necessary for the tailgate ajar light to work. Then it will need to be activated with AlfaOBD.
Technically, it's the other way around. alfaObd had more options to enable factory options. TazerDT has live features that alfaOBD will never be able to doPardon my ignorance, but is alfaobd akin to what the tazer does?
I feel it latch shut, it just doesn't register digitally. I didn't try kicking it from the inside to see if it would open though.You and me both. I sprayed some dry lock lube on the latches today hoping it would take care of (or at least help) the issue. I guess we'll see once it works it's way around the mechanism in a couple of days.
I did not have this issue with my old 2019 Laramie. Then again, I had a regular tailgate vs the multi-function one I have now. Not sure if it makes a difference.
Calls the police, "There's a bunch of ammo on the road".I had mine open just once. Unfortunately, I lost ~$2000 of ammo and another $1000 worth of Christmas gifts because of it. I immediately got AlfaOBD and activated the tailgate ajar warning to ensure it never happens again. I reported the lost ammo to the police, but it was never found. They said they received a call about a bunch of ammo on the road, but by the time they got there, it was all gone.
The recall isn't for MFTMine dropped while I had a trailer on it. Scratched the tailgate badly. I have a 2020 with the MFT and the warning light. It did warn that it wasn't fully closed, only noticed when the surround camera was blacked out at the back.
Sent from my SM-S908W using Tapatalk
