Today (Sunday) I received the bolts for bed rail. I did ordered the bolts about 1/4" too long but nothing some washers and crush washers can't fix, right
After I made holes for the bolts, I made a harness to run everything to engine bay.
Since I am also running chase lights, I combined both the power box 8 gauge wires and the chase lights 14 gauge wires into one sheath. I had to extend the BD S2 harness, as the one I had was too short for full size and ya boy is too cheap to spend another $100 on BD extension harness. I simply cut off the ring terminals and the fuse (that I did not cut off when I did it on the 4Runner), extended the wires, and put new ring terminals.
I first by ran the sheath externally from the bed to the engine bay, then added about 1' or so of additional sheath to account for running through the bed and up the bay. Then, I used the sheath as a guide and cut both power and ground cable for the BD light, and fed all of them through the sheath. When I was done, I pulled additional 1ft of 8 gauge for running to the box and for reserve.
*One thing I learned after doing 12v electrical on vehicles for a while is that you can never get exact length of wires right, unless you're doing short distance measurable by arms span. Luckily, wires and cables are cheap enough for a little bit of "waste," which we usually keep for short distance applications.
Since I don't have proper heat shrink for this sheath size, I opt for temporarily ziptie the end of the sheath close, then use e-tape to close them off later. Then, I went under, and ziptied the sheathed harness to the frame, or more precisely, the existing harnesses along the frame. There were only a few spots that I tied it directly to the frame due to my fat *** prevented me from reaching. I may change that later when I install rock lights on a lift though.
As I pulled the harness out from engine bay, I realized I could've not do the reserve and I'd still have plenty of wires left for reserve. Later, I realized this is discrepancy was due to I took some shortcuts while ziptie the harness in addition to the 1' reserve. No big deal, as leftover wires are better than not enough wires.
As I connect everything together, I realized one glaring problem: I cannot do basic math and I am 3 8 gauge ring terminals short. So I attached everything and heatshrink the power cable for the power box and called it a day on that part.
I also installed chase lights and make sure everything works properly, including the strobe function. I utilized the old spot on my previous setup, but I may change the location since there will be a few blank spots as I am not running roof lights, and camp/ bed lights will be wired to the power box.
Here is what the finished power box looks like. Since it is not completed, I ziptied it to the bed rail along with my solar panel harness. Once I finish it this long weekend, I will clean it up better!
I purposely put the power box at that location since I like the idea of leaving Decked ammo box functional. Not sure what I will be putting in there yet, but most likely will be some dirty stuff (maybe reusable utensils, or even green propane bottles, or dirty beach clothing? who knows)
