boogielander
- Jun 29, 2022
On Christmas Eve I decided to go to Johnson Valley the next day to do some photoshoot, have lunch, and do some testing.
One of my buddies decided to go with me (single guys, no Christmas thing to do lol)
Every time I look at that GFC it just makes me want to get one too, but I can't cough up that much for a camper tent
Got to JV at around noon-ish and tried some trails. Found some problem with bed rack/ roof tent setup: when going on rutted trails, the weight of the tent would create this side-to-side motion which shakes the rack and the side panels are not staying where they are. This is due to a few things:
Aside from these discouraging findings, the day went well. We had steak in the middle of the dry lakebed, chilled for a bit while waiting for golden hour. I started positioning the trucks and snapped away when the light was right, and managed to taught my buddy how to take rolling shots.
One of the shots I took for his taco.
Ended the day with a beautiful shot like this.
Tomorrow I will be going under the truck to check every nut and bolt that I've turned when I installed the Fox, and hopefully nothing is missing/ loose
I mean, everything should be fine because I drove ~100 miles home and the truck felt fine!
- Weight of tent. The tent, given that it is motorized hardshell with solar panel on top, is at least 160lb. For camping and fire road this is fine. But if I want to tackle King of Hammers desert trails (not the crawling section) or attempt to do TRX/ Raptor things, this is a problem. And I want to attempt TRX/ Raptor things.
- Rack is not boxed frame, so structural rigidity is not enough to handle the constant shifting weight of the tent.
- Side panel hardware are not tight or the weight of the accessories are dragging the panels down when going through whoops.
- Get rid of the tent. For day runs or high speed runs I remove the tent and only put it back for overnight camping trips.
- This is only a band-aid solution, as I am certain I will be going on trips where going through rutted trails when I do extended days trips. And I will be facing the same problem again.\
- Get rid of roof tent and sleep on the ground. This is not ideal either because I don't want to deal with getting myself all dirty while pitching or putting away ground tents. Also I don't want to be dealing with pitching tent after a day of driving or extra time to pack up ground tent in the morning.
- Sell this tent and get a lighter weight option. This is the solution I decided to go with. I am looking at light weight options such as GFC Superlite V2 or Inspired Overland options as they are lightweight and relatively affordable. So if anyone local in SoCal is looking for a motorized roof tent for cheap please let me know (or if you know anyone looking for one, please send them my way!)
- This problem is more complex. I need to find a way to "box off" the top portion of the rack to provide more structural rigidity. Basically right now the tent is sandwiched on the bed rack, while I tried my best to tight down the nuts and bolts, it is not enough. Here's the situation:
- The more I tight the nuts and bolts, the top cross rails just end up splitting due to the clamping force. Which then make the whole sandwich not as tight as it should be.
- So this will be a two-part solution:
- First, I need to get another 2 sets of tent mounts. One set will be sitting on top of the cross rails running parallel to the existing tent mounts and tightened with nylon nuts. This will create a clamping force that's not solely relying on the weight of the tent. In addition, I will also need to add another pair of mounting for the middle cross rails and do the same sandwich.
- Second, I need to box off the top. Reason is that currently the top portion is a C channel frame, and as we know C channels are not as rigid as boxed channel. One example is early Toyota Tacoma that suffer from bent frame just with daily work use. They are just not as strong. That's why most trucks built to last (like ours) have boxed frame instead of C-frame. I will need to get in contact with Chassis Unlimited to see if they can cut something for me and correct this issue.
- This should be a simple fix: Tighten all the carriage bolts and use locking washers to grab on to the slot opening. The nylon nuts are not loose at all, as the reference markers have not moved. So I know it's not the nuts getting loose but more of a hardware not tight enough or not grabbing to the rails. My two-step plan to attack this problem should prevent similar issues from happening again.
