UConnect 26.15 Update Thread
mac424
Here's a question. Why is it that we seem to know there is an update, but when you navigate to Uconnect's website and check for one, it tells you there isn't one available based on the VIN.
I can totally see why a file is never able to be downloaded. Someone will probably end up bricking a radio. It would be nice to be able to "check" for an update via the radio vs it being pushed.
There's also no way for actually push an update to specific radios either, huh?
tech97elec
Maryland
Your vehicle should of never had the S26.15, that was never released to the public. If you do have that, you should get the S26.17 when it becomes available for your region.
William
Ram Cares
As i pm'd you.... my vehicle too has 26.15 and i havent done a thing, so saying it was never released is not true. At least 2 of us have that version and i agree.... "should of never had 26.15".... it has issues.
I DO have OTA software enabled, so must have updated like that or has been the initial version when i purchased my truck new in Nov of 2022.
I have appt pending with dealer, but would like to know if 26.17 will fix issues im having? Isnt there a list of "fixes" that 26.17 addresses?
RamCares
Michigan
This update has not been released nationally at the moment. Here are the list of improvements on this update per TSB: 08-211-22.
RamCares
Michigan
and what about the export market. Is 26.17 released globally now? So if I would go to the dealer, they will be able to update my v23 to vs 26.17?
This would be for the U.S market. Before you can get the S26.17, your vehicle would need to be at 24.13/24.18.
William
Ram Cares
Q8hawk
Hello All, could someone with hookups help us get either 24.13/24.18 updates?! Our region OTA is broken and our dealers do not give flying hoot! Help is needed, thanks! Our TBMs are fine!
Pejcinoski
I have updated to the 26.15 from 21B5 successfully Australian conversion.
Is there a way to turn the Wi-Fi hotspot on somewhere in the settings as it doesn’t appear anywhere in the settings also I have turned the feature on with Alfa OBD but it doesn’t come up
Dewey
WI
Turned off my truck last night and an update popped up. Guess I’ll see how this one works.
Eighty
Moderator / Dream Killer
Ramcares stated this earlier (on the TRX forum). I guess you're close enough to there...
Release are being done in Michigan currently right now, then it will be distribute nationally.
Dewey
WI
Guess it made it across the pond to WI already. Got mine just before midnight last night.
Dewey
WI
Well my heated seat/wheel icons stayed since last night. That’s a plus but we shall see. Last update before this they disappeared again a day later.🤨
Haven’t noticed anything else different so far.
Jimmy07
Honorary Site Supporter
I guess the 8 inch version number is different
mine states
Version Information
Build Number
FCA_R1L_ARM_00.145.00.15.00 release keys
I’m guessing you have the 8.4 non nav radio? This update thread pertains to the 12” and 8.4” with nav radios.
Darksteel165
Massachusetts
My radio just got an update today.
I was already running S24.13 from June 13th.........................................
Good job Ram.
