i_squared_r
- Aug 26, 2022
How did you tap into the cargo light? Run wires up through the back of the cab? I was thinking about adding bed lights to mine also. The tailgate ajar is already activated thank god.
There's a thread somewhere that details how to tap into the cargo light. In the backseat, driver side, remove the floor door jamb plastic piece, open the black channel that wires go through, and look for a wire white with tan tracer. (Wire color is from memory so it's better you check before starting the job) I used one of those blue electrical taps, pulled back the carpet to expose the plug in the floor, ran the wire through that plug, and to the fuse panel that I installed behind the rear tail light. )I opted to install a fuse panel with dedicated power from the battery because I have other accessories.) Some people say the BCM throws errors if you draw too much current through that wire so people changed the original cargo light to LED to reduce the current draw. But since I have a fuse panel there, I took power from there and added a relay that is triggered by the cargo light so it's almost 0 current draw on the cargo light circuit.
