I just completed the install.  Here are my notes.  5 hours from start to test drive.
Got my kit from "Airlinks" with the front and rear and the daystars.  Half the price of Revel and the quality is definitely as good.
Bought the UCAs fro the 2" lift kit.  Didn't do any good.  Couldn't get the old ones off.  I got to the point I thought I was going to break something.
Cutting the studs on the struts is the crappiest part.  Due to the heat and crappy threads, it's difficult to get the new stud sleeves threaded on.  I did put the old bolts on before cutting, but I was still using more torque than I was comfortable with trying to thread the new sleeves on.  Got them on though.
Torquing all the bolts sucks too.  I didn't have a couple of deep sockets I needed (18 mm specifically) and couldn't torque some with a wrench.  I've never liked crows feet, so with some of them I just put about where I think was about right.
I couldn't break the black plastic fitting.  I just unscrewed the brass fitting like in the video.  I don't see what benefit there is to doing it at the plastic.  It's just a plastic 90.
There was a lot more nitrogen that came out than I thought there would be.  It took like 30-45 seconds to slowly bleed out when I partially cracked the fitting.
I didn't take the brake calipers off, but I probably should have.  There were some times when I had more strain than I wanted on the brake line.
For some reason my truck sits about 1/4" higher on the passenger side.  It was that way before I did the level.  I have to see if I can fix that.  With everything set up just like it was in the box, have about 3/4" rake and that's exactly what I wanted.
Drove fine after I was done.
