*OFFICIAL Rough Country 3.5 // ReadyLift 3.5 thread.
On a Rebel which already has 1" lift over the standard RAM suspension, will I only net 2.5" of lift out of this kit or will I actually get 3.5" over stock Rebel suspension?
I’m not 100% on this but likely 2.5” net. It replaces the entire front spring and strut. Good news for you is if it’s 1” taller in the rear already and you’re using a rear spacer you’re already 1” higher in the rear bc you’ll use the factory springs. Be sure to post a pic once you do this. I’d like to see what your truck looks like after
Chatted with two different people at RC. Nobody can tell me what is in the kit that makes it $200 more than parting out the individual components. They just assure me that it's "cheaper if i get the kit".
Both guys closed out the chat when I pressed the question. Seems shady to me. I'm going to get the individual components but with the $200 difference it makes me wonder what's in the kit that I'm missing.
Maybe I should go with ReadyLift, Maybe I just need to let it go :p
I bought my ready lift kit on Amazon for 600. cheaper then anywhere else. But also bought 5100's for up front.
Someone correct me if I'm wrong. But basically you are lifting it 3.5inch, which would be like me lifting mine 4.5 inches. Anything over 3.5 will be creating some bad angles. That why all the 4inch kits have all the extra components. There kits say not to be used with org. But if you buy the kit that comes with new strut and spring. Then yes. You are really only getting 2.5 inch of lift. So just bought buy the kit where you reuse your spring.
I have the RL 3.5” kit. Running 35x11.5R22 Nitto Ridge Grapplers. Everything fits great and has the stance and look I was after. Problem is the wheel hub/knuckle makes contact with the Lower Control Arm. And by contact I mean that it has cut into the metal in full turn aka trying to park. Had the shop call Readift and they said they knew about this issue and we should just grind down the points of contact. The other issue is that with 35’s it seems to be exceeding the maximum span of the OE parts. Because there is a very noticeable negative camber. I am working with another custom shop now to see how to correct this. Is anyone else having this issue?
What ended up being the best solution for this issue? I am picking up my 2022 Laramie night edition on Monday morning. I was going to go with a RC 3.5” level kit with struts. I have Kenda Klever RT 35/12.5r22 tires on order. I am guessing I will have the same problem as you and I need to go a different route. Can I do 2.5” level instead or is a 4” BDS my only option?
So I bought a 19 Bighorn that had the RL 3.5" Kit already on it (with the UCA's) and to me it rides pretty freaking rough. There is also a "clunk" sound coming from the rear that sounds like the spacer for the rear spring is loose somehow? My question is, can I just add some Bilstein 5100's up front at 2" and keep the 1.5" top hat spacer and get an improved ride up front? Also on the rear, who all makes springs that would work with this kit so that I could eliminate the metal spacer?
Been a minute since last updating mine within this thread. Figured I should do so.
ReadyLIFT 3.5” SST
Yokohama Geolandar G003 MT
315/70/18 (35.6”x12.4”)
Black Rhino Rapid Wheels
18”x9.5” -18mm offset
I see no one has replied to you. No you cannot do the Bilstein's and the top hat. It would destroy your front end. You can set the Bilsteins to about 2.8 inches and have a much nicer ride that the RL kit. Keep the UCA's on. Carli, Icon, and Eibach all make 1.5 inch longer springs and you could get rid of the spacers.
What did you end up doing? I’m trying to figure out all the math for my Rebel right now. I’m looking at just getting the RC 3.5” loaded struts and UCA and that is it. Right now with the factory 1” lift my front end is 2” lower than the rear. So putting in the RC struts would net me 2.5” and make the front end about .5” higher than the rear (and hopefully after some settling pretty level).
Am I missing something? I feel like if I add any spacer to the rear the rake would come right back
But then looking at the RC 2" loaded struts there are a lot of reviews stating these levelled people's Rebels. Picture here: 2 inch Lifted 2019 Ram 1500 4WD
I am thoroughly confused! Haha
I have Bilstein up front on setting 5 with my top hat spacer netting 3.5inch lift up front. The rear I have the spacers and stock springs. Truck rides little more rough then stock but really not to bad. When you hear the clunk when do you hear it?
To follow up on my previous post, I went with 2” RC loaded struts and for the Rebel it was enough to make the truck pretty level
Sorry man, I've been off the forum for a bit. I haven't had time to do anything yet plus all the math had me thoroughly confused. What parts list did you end up going with? Was it just the RC loaded struts? Do you have pics before and after? Would love to get a lift but I'm stuck with stock rubber until it's time to replace (then bigger). Will most likely stay with the stock wheels.
Mines the lifted one 3.5 rough country with 35 12.50 18 Lon the stock wheels both 2020
Second pic one on. Right is lowered 2”
Mine has some heavy duty springs in it now so lost my level them stock ones can’t handle weight
2” loaded struts and replaced UCAs View attachment 167653
Which strut and what uca? I'm going down from a 3.5" to a "2 level lift and have been shopping around trying to find what I want. I was going to go el-cheapo and just get the 2" block for the front to see how I liked it and if I had rubs anywhere, then eventually upgrade to the bilsteins and new control arms for peace of mind but don't want to be breaking the bank for the whole thing, again.🤪20220312_124621.jpg
Slightly older pick of it before I plasti-dipped the whole front grill red (will be shading it down now though because way to much red) and a headache rack with a customized light bar installed on it.
Nicknamed "RAMbo Edition" or
"Umbrella Edition" (RESIDENT EVIL FAN)
Not sure which one I like better yet.
Which strut and what uca? I'm going down from a 3.5" to a "2 level lift and have been shopping around trying to find what I want. I was going to go el-cheapo and just get the 2" block for the front to see how I liked it and if I had rubs anywhere, then eventually upgrade to the bilsteins and new control arms for peace of mind but don't want to be breaking the bank for the whole thing, again.🤪View attachment 168353
rough country for both
readylift 3.5 " with nitto trail grapplers 35x11.50 with 20" fuel titan wheels 20x10 with -18 mm offset. The tires did scrub at full lock but i heated the plastic wheel liners up and pushed them away from the tires and they dont scrub. Im overall happy with the looks and the quality of the lift.
If you still have this truck would you mind measuring the floor to fender heights front and back. This truck looks amazing
3.5" Rough Country lifted struts and spacers for the rear. TRX wheels with 325/65-18's. I also have 1.5" spacers installed to clear the uca. Had to do minor trimming of the wheel liner in the back1000001029.jpg
Has anyone here used the Rough Country 3.5 Loaded Struts on the ReadyLift 3.5 SST kit after factory struts with pre-load wore out? Debating on whether or not to go with Rough County 3.5" loaded struts or use the Bilstein with 0-2.6" pre-load with the top hat spacer from the Ready Lift kit.
I have the same question. Fronts are starting to wear out. Was considering either the RC 3.5” N3’s or M1’s but was curious about the lift height difference, if there is any
