It looks like you get the best gas mileage in America, it helps that Florida is so flat, close to sea level and warm compared to the northern states.
You’re right a camper is a real damper for gas/fuel mileage, I’ve towed my 8x16 enclosed trailer (not V nose) for many miles, 2300 lbs empty, the mpg was very close loaded or empty, the bigger difference was the head wind, 17 mpg with a head wind, the front of the trailer was buckling with the wind gusts, up to 21 mpg with little to no wind. Note that it’s mpg for the Canadian gallon.
I bought a small 14 1/2 foot travel trailer, single axle, with full propane and fresh water it’s under 2500 lbs, it’s 7 feet wide. Last summer we did a 1500 mile trip, I could not believe the wind drag that little camper has, I really though it would pull so much easier than the enclosed trailer, thinking it’s the same weight and being a foot narrower, the big difference is the enclosed trailer sit a lot lower. I did achieve the same fuel mileage for both trailers, still disappointing because I was expecting mid 20’s. We will be traveling across North America in the summer months.
I also have a 1999 29 foot travel trailer, back then the trailer had drop axles, they sat a lot lower, the problem was the sewage connection were really close to the ground and could get ripped off, it happened to me on my 1979 trailer.
On my 1999 trailer I moved the drop axles from the top of the leaf spring to the bottom of the leaf spring, it raised the trailer more than 6” I needed the ground clearance to go on rough bush roads.
This summer before our trip to Newfoundland I will move the axle from the bottom of the leaf springs to the top of the leaf springs, it will drop the trailer height by more than 6” I’m going to install a steel guard around the sewage connection for protection. I will also install a skirt at my rear bumper and at the front of the trailer
to stop debris and wind from hitting the lower part of the trailer. When there is less wind going under the truck and trailer, it reduces the down draft between the truck and trailer creating less wind drag. Hopefully my predictions will prove themselves.
