Nbt22555
is the security by pass cable needed for all 2019 vehicles to do programming or just certain vehicles? Also I have an obd plug that goes from my computer via a usb end to my obd connector, it is for my pulsar unit that piggy backs to the ecm, do you think i could use that cable and run the alphaobd program? or do i need to buy the wireless plug in part?
georgesrt2020
Anyone know how to turn on Performance pages on JScan ? I just updated my software to 39.7 and can’t seem to find the setting in JScan…
stormcom
Has anyone done this successfully yet?
I just got done putting a 12" in my big horn. was not a hard job. you must follow instructions word by word. Now that it is in, it is very enjoyable. Went from a limited to a big horn and now trying to put a few luxury items in the big horn.
stormcom
Just a recap on the info we have here to make the conversion from 8.1 NON Nav to 12.1 Nav:
Rewire cable with blue tape to match 19RamLimited Picture
get cable to override 911 message: https://www.infotainment.com/products/911-vehicle-phone-override-cable
get LVDS Cable: https://www.factoryradioparts.com/p...e-differential-signal-jumper-cable-05064684ad
get Radio Module: 68317978AI
get 4c Uconnect Navi 12.1 screen.
Is this accurate to make a FULL conversion? or am I missing something?
I ordered part number 68082364AC LVDS cable and it is 31". It was easier to assemble with my fat fingers.
georgesrt2020
So I purchased AlfaOBD, for 2021 Ram Rebel 12" UConnect to program Performance Pages.
Performance pages are working on the Uconnect. But I am not getting anything on the cluster just a blank page, Did I miss something ?
I changed settings
VehConfig 1-Performance Pages Present = YES
VehConfig 2-Off-road Capable =YES
VehConfig 5-Off-Road Pages Present =YES
and I also set it to
VehConfig 1-Special Package - DT TRX/Laramie Limited
Truck shows 4WD needs service when set to SRT ON, so that is now OFF
Srankins12
So far it has been the most stable the radio has ever been both CarPlay and Android Auto work flawlessly. The update also allows Off Road and Performance pages. Still tinkering with the pages though. That being said this is a retrofit and SiriusXM Guardian does not work anyway.
when you do the update, what files are in root? There is that same folder in two different places. Do I just pick one?
MannyN
Don't use the _MACOSX folder one.
Use the one from UCONNECT_12_UAX_PR39.7.
Only copy the folder VP4R_Update to the root of an empty USB Drive. Do not copy the .DS_Store file to the USB Drive.
Nbt22555
finally had a chance to get the performance pages turned on. Everything seems to work except the g-forces and pitch &roll never moves always at zero. Anyone else have this? I would think the vehicle has a yaw rate sensor in it somewhere. 2019 ram limited.
MannyN
I think the sensor is only in the off road package, mine does not work either.
azzx
Central AZ
On my 2019 the current software version is: 21.32.14
Hardware part number is: CNSC28NOGL
1- Can this be updated to 39.7?
2- Install 34.2 first and then 39.7?
3- Has anyone with the same hardware version done it successfully?
My factory warranty just ended, dont want to risk turning the unit in to a brick!
MannyN
This is what you want to look for. The application file will be updated.
azzx
Central AZ
I have the same application # that is on your pic.
So, it is OK?
Thanks
azzx
Central AZ
OK -- so my truck is not capable of displaying off-road pages?
that is the only reason I was looking at the 39.4 update
thanks
MannyN
thanks
You need version 39.7.0 and AlfaOBD to turn them on.
rturner026
Does anyone have a link for the antenna needed for 4g/lte/wifi when doing the 12" conversion? Anyone been able to get mopar/uconnect to activate it?
Rhombus
Cedar Park, TX
Regarding current pricing. I have a 2020 8.4 with no-nav. I just spent about $1800 on all the parts last night. All new. Folks on eBay are wanting more than that for used. now I wait for delivery…….
acitalianman13
Hey has anyone here installed a 12” display in a ram 1500 bighorn 2019 ? Had some questions lmk thx.
