I got my set for $1,800 in the St Louis. MO area.What are you guys paying for these take off’s? I’ve got a set near me but want to make sure I’m not getting screwed.
Just curious - any updates on this one? Have you installed 3/4 spacers?Strong work! Looks great. I’m gonna do the 3/4 spacer for now and see. Likely adding a 3.5” lift (net 2.5” gain) over time.
I'm interested in TRX wheelsPode acabar negociando no caminhão e pensando em vender os TRXs que acabei de comprar. Estou na área de miami
Enviado do meu iPhone usando Tapatalk
I’ve got the trx wheels, will add the 295/70/18 tires to check if its rubbing or not.
Ive ordered levelling kit of 3”front, & 2 rear.
Now im confused on the spasers seems like a must.
What if I changed the upper control arm will it still rub?
Or have a smaller tire size??
I got two sets one from Facebook for my friend who owns a TrX but wanted the beadlocks.Hi, where did you buy the wheels?
thanks
I have air suspension. Leveled using daystar spacers and airlinksgc level links in the front and rear.I’m interested in a set of TRX takeoffs (wheels and tires) as well. I’m currently running a leveled ORP with 1.5” BORA spacers. Can anybody say whether the 325s will fit with this setup… or if I can easily modify to make it fit?
Have TRX beadlocks and 325/60s with 1.5in KSP spacers. Little trimming and truck has no problems. View attachment 116326View attachment 116327View attachment 116328
My truck says 13.5-14mpg most of the time. I havent recalibrated the speedometer or added any of the piggy back tunes (PC, Pulsar, and so on).Thanks, I appreciate it.
Dare I ask it: how’s your fuel mileage?
Also have 1.5" BORA spacersI was able to get these Ram TRX wheels and tires running on my 2019 Rebel (with no lift or leveling kit). As others have stated, I had to remove the hard plastic mud flats on the front and use an exacto knife to cut out some of the wheel liner. I also bent the small medal bracket (that the mud flap screwed into) back into the wheel well. Only issue I have is the TPMS sensor threshold that keeps telling me I need to put 55 lbs in my front tires and 45 in my rear tires. The TRX tires are designed to run 38 lbs of air pressure. Anyone find a way to reset the sensor threshold to 38 lbs?
Alfaobd allows you to adjust tpms thresholds to whatever your heart desires.I was able to get these Ram TRX wheels and tires running on my 2019 Rebel (with no lift or leveling kit). As others have stated, I had to remove the hard plastic mud flats on the front and use an exacto knife to cut out some of the wheel liner. I also bent the small medal bracket (that the mud flap screwed into) back into the wheel well. Only issue I have is the TPMS sensor threshold that keeps telling me I need to put 55 lbs in my front tires and 45 in my rear tires. The TRX tires are designed to run 38 lbs of air pressure. Anyone find a way to reset the sensor threshold to 38 lbs?
ThanksAlfaobd allows you to adjust tpms thresholds to whatever your heart desires.
