KWKSLVR
No, but it still shouldn't have broke like that. Slowly backing out of a driveway shouldn't break anything.Oof. Not a good use of 4LO and locker
Agreed however use of 4LO should be the last thing you utilize before calling a tow truck or a buddy you’re mud bogging with to pull you out of extremely deep snow or mud.No, but it still shouldn't have broke like that. Slowly backing out of a driveway shouldn't break anything.
That's what my '14 Ram's manual said, but the '21 says you can do it stopped too.Just wondering, doesn't the RAM manual (or other sources) say you MUST be driving at a low speed in order to switch to 4-low? Other modes, 2wd, 4-auto and 4 high can be switched at a stationary position (or while moving)?
thanks!
What's a clunk? I don't know what you are talking about.Holy **** Batman…… !!! Don’t say anything, “dunno, there’s a clunk Under my truck and it no go….”
Fluids levels? I read somewhere on here that others were experiencing harsh noises and vibes coming from the rear diffs. Reportedly, it's because some MY22s were being shipped with low fluid levels in the rear diffs. If that is the case, is it possible that the front-end transfer case could also have been improperly filled?Story time everyone,
So I’m in New England, just south of Boston. Yesterday about midday, I decided that I’m going to the gym before the snow gets to bad and I actually have to shovel my truck out. (There’s about a foot in front of my driveway from the plows). So I start the ol’Rebel up for about 10 mins, slam some Pre Workout and it’s time. I put the truck into 4Low, lock the locker (because why not), then proceeded to inch forward; I feel resistance… give a little gas, she starts to crawl…. Then !!!POP**CLUNk**!!! I stop. Put it in reverse, the clunk gets worse! So I back her up back into my drive way. Proceed to shovel everything around the truck so I can crawl under… the Transfer case snap off the bolts and the front drive shaft is laying on the sway bar
Now the feeling of (my damn new truck is broken [1100 miles]) + a two scooper of Pre Workout is sitting in my dome piece… please sweet baby Jesus I hope the dealership doesn’t say I was doing dumb **** and broke it!!
I agree, I don't see the relationship either.Not sure why many of you are hung up on him using the rear locker. That would have no effect on the front driveshaft breaking. And I use my rear locker to "play" quite a bit
I was just using it to get out of the driveway, the option was there and the truck only has 1200 on it. I figured it couldn’t hurt, I had no idea why it broke like that. The fastest the truck was moving was maybe 2/3 MPHI’ve been driving four wheel drive SUVs and trucks since the 1970’s, and have used 4LO only twice - in 3-1/2’ of snow on an icy road in a mountain pass at night in Alaska and I was creeping along to ensure I didn’t spend the night in the ditch (wherever it was) in the middle of nowhere. 4HI has always been sufficient. Granted, the front DS shouldn’t have snapped but I’m curious why you choose 4LO or is it a typo? Have you driven it in 4LO before?
Did you make the shift to 4low in neutral?I was just using it to get out of the driveway, the option was there and the truck only has 1200 on it. I figured it couldn’t hurt, I had no idea why it broke like that. The fastest the truck was moving was maybe 2/3 MPH
I was in neutral when engaging both 4wd and the E locket. It was working completely fine till I started to move forward and hit any resistance. Gave it a little throttle (was not enough to start a spin), I did turn the wheel and then the sadness happened. The only thing that I can think of is when the wheel was turned, it put leverage on the housing, and the metal was cold enough that it became brittle.Did you make the shift to 4low in neutral?
Did the shift complete before you selected drive?
The driveshaft breaking is very surprising.
Was your steering turned when moving forward?
noun:What's a clunk? I don't know what you are talking about.
Hey Bay Area, I just moved to Boston from Vacaville… I would never of had to worry about this there… just ash getting all over the paint lolnoun:
clunk; plural noun: clunks
1. a heavy, dull sound such as that made by thick pieces of metal striking together. "there was a clunk under my truck when I tried to simply drive out of my F’ing driveway"
Man, I think this is a freak accident. This is my fourth Ram/Dodge truck and nothing like this has ever happened before.This is disturbing. I’m going to have to test mine out before I install my leveling kit in a couple days.
