AlfaOBD
MannyN
What is PR39?
The latest software update.
What is PR39?
Start reading from here.
Idahoktm
North Idaho
Thanks. It looks like I'm good to go.
MannyN
Mine is really old. It is like 35. I wonder if I can get them to push an update or if I can pay the dealer.
There is a link to download them.
Edmontonram
Wondering if anyone knows what the latest software version is for the 8.4 Nav radio ?
Having a hard time getting a setting to take in Alfa, wondering if this might be the issue.
Thanks
vincentw56
Great, I was able to update to it. I enable the pages, but I don't see them yet. Of course, I know it takes a few for it to show up.
Jimmy07
Honorary Site Supporter
Great, I was about to update to it. I enable the pages, but I don't see them yet. Of course, I know it takes a few for it to show up.
If you connect to the radio with AlfaOBD (2017 navigator module), and reset the ECU a few times, it will force the settings changes to the radio similar to what tazer does with a reboot.
vincentw56
For some reason I cannot connect to it. I'm using the Android app. Also, just so I know, how do I get to the pages? Is it in the Uconnect apps section?
Idahoktm
North Idaho
So, did you just download the file onto a USB drive then plug it into one of the USB ports under the screen?
Jimmy07
You can only connect to the radio module if you are using the type of gateway bypass that replaces the security gateway module. It can’t be the kaodtech style OBD port bypass.
Brutal_HO
The Mad Irishman
Douglas County, CO
there is a tone of info in this thread, apologies if it been asked.
will any brand alphaOB2 work ???
alfaOBD is an app. There is only one app. If you are talking about the OBD2 device that plugs into the truck, it sounds like it's hit or miss on some of the cheaper devices. The preferred device, that is known to work, has been posted multiple times
are you trying to tell me, **** off and read the information in the thread? because it sounds like you know the answer and just dont want to give it?
Wow. He gave you a valid answer to a question that wasn't asked in a clear manner.
"any brand alhaOBD2" is a gobbledygook conflation of two different things.
jdpanero
You need to recalibrate it in AlfaODB. From what I've seen, it is best to do it in a well lit parking lot with plenty of cars. It likes a lot of objects to look at.
Do you know where to find recalibration in AlfaOBD?
Brian B
VehConfig 1: Auto Highbeam- YES
**2014 CBC Config I/O & Feat.: Auto High Beam Module Location- IRCM**
CustSetMenu 1: Auto High Beam CSM Present- YES
**CustSetMenu 2: Teen Key Automatic High Beam CSM Present- NO**
Cust.Prog.Features: Auto High Beam- Enabled
Do these settings apply to my 2020 2500 as well?
Jimmy07
ONLY if you currently have forward collision warning. If not, then you need a different rear view mirror, and the settings will be different.
