That sounds like the pid is not converting properly, or you’re not reading the pid that you think should display boost in psi. Atmospheric pressure is roughly 14.7, so it’s likely that you’re actually near 0psi.Is it normal to have a boost psi of 14 at idle?
Even when I **** the truck off the gauge reads 14 psi?
