This is what I needed, thank you! Do camper dealers typically advertise the dry tongue weight? I feel like I only see the total trailer weight on the listing. I found a 28.5' around 6,000 lbs, sounds like I will be super comfortable with that?
Do you also think I need the upgraded hellwig sway?
Hi - I have a SportTrek 251 VRK (28.4 feet long) dry weight is 6060 - dry hitch weight is 770. We have a better mattress and with the camper loaded with all the necessities it weight around 6800 and the hitch weight is 910. That is with 10 gallon of fresh water. This is just a guide and I cannot make it work within my payload of 1293. the extra 300 lbs of payload you have will make a big difference.This is what I needed, thank you! Do camper dealers typically advertise the dry tongue weight? I feel like I only see the total trailer weight on the listing. I found a 28.5' around 6,000 lbs, sounds like I will be super comfortable with that?
Just wondering, if your trailer was 800lbs lighter (i.e. it stayed unloaded), would it be doable? Asking cause the trailers I'm looking at have dry weights around 5300lbs, so my loaded weight will probably be only a bit more than your dry weight (and my payload is right about where yours is, 1268).Hi - I have a SportTrek 251 VRK (28.4 feet long) dry weight is 6060 - dry hitch weight is 770. We have a better mattress and with the camper loaded with all the necessities it weight around 6800 and the hitch weight is 910. That is with 10 gallon of fresh water. This is just a guide and I cannot make it work within my payload of 1293. the extra 300 lbs of payload you have will make a big difference.
That trailer is AWESOME I may try to go with it...you think my truck will tow it easily and within the safe range?Hi - I have a SportTrek 251 VRK (28.4 feet long) dry weight is 6060 - dry hitch weight is 770. We have a better mattress and with the camper loaded with all the necessities it weight around 6800 and the hitch weight is 910. That is with 10 gallon of fresh water. This is just a guide and I cannot make it work within my payload of 1293. the extra 300 lbs of payload you have will make a big difference.
Others can provide more specifics and details but basically:
Payload is the key number. You will hit that way before you hit your max tow.
The "Dry Hitch Weight" that TT mfg's list on their websites is a magical nothing burger. Loaded hitch weight is what matters and that will include the dry hitch, batteries, propane tanks, and your Weight Distribution Hitch (WDH). Speaking of which...
A WDH is pretty much a must when towing anything over 3,500lbs loaded (which a TT big enough for a family of 4 will be). They control sway and spread the weight pressing down on your hitch out to the trailer axel, and toward the front axle of your truck, so it's not excessively concentrated. People around here like the Equalizer, but there's many different brands that are better or worse with various different aspects.
A stronger sway bar helps, and is something pretty much everyone here will tell you is a must-do mod (even if you're not towing). Hellwig has this market cornered.
LT ties may or may not be needed. Some people swear by them, others insist they're overkill. If you have XL-rated tires already, my advice would be to try with them first and see how things feel. If you feel like even with a Hellwig sway bar and dialed in WDH you're getting too much sway and lean around curves, consider LT tires. Tow mirrors are in a similar category.
Now the preachy stuff...
Changes lanes as infrequently as you can. However fast you think is comfortable, drive 5 MPH under that. Pull over in heavy rain/strong winds. Be extra conscious of anything on the road bigger than you (i.e. tractor trailers). And make sure you enjoy the drive! If you find you can't, you might need a bigger truck (or a smaller trailer).
Speaking of trailers, with just a very surface-level read off of your numbers, you'd want to stay with a dry hitch weight under 800lbs, and length under 32 feet. The dry and loaded weight of the trailer is a whole nother topic and I've rambled enough as it is and will let someone else handle that. Everyone here was super helpful to me, and they will be to you as well!
Payload is the magic number, what's yours?SportTrek ST251VRK Travel Trailer | Venture RV
View the SportTrek ST251VRK lightweight travel trailer floorplan, specifications, 360 virtual tour and quick tour video.www.venture-rv.com
Is this a good option for my truck and a first time "tower"?
800 lbs of necessities?Hi - I have a SportTrek 251 VRK (28.4 feet long) dry weight is 6060 - dry hitch weight is 770. We have a better mattress and with the camper loaded with all the necessities it weight around 6800 and the hitch weight is 910. That is with 10 gallon of fresh water. This is just a guide and I cannot make it work within my payload of 1293. the extra 300 lbs of payload you have will make a big difference.
1,543Payload is the magic number, what's yours?
That's a solid figure. Like @Gazza suggested, your extra poundage over his payload probably makes the difference between safely towing that camper and not. A good estimate of your actual loaded hitch weight (including propane tanks, batteries, and your WDH) is +200lbs over the dry number, so figure a tongue weight of at least 920lbs. That leaves you about 620 lbs for stuff in the truck, so then it comes down to how big your family is.1,543
Havent gotten my loaded trailer to scales yet but I’m really hoping I haven’t added 800#
Sorry, I misspoke (mistyped?) Yeah, they show my cargo capacity as if I had a full fresh tank, exactly as your plate shows.Dry trailer weight is calculated with empty tanks, not full fresh water.
I assume you are confused by the cargo capacity label which lists different scenarios of weight carrying capacity depending on if the tank(s) are full.
As mentioned in this thread...the non VIN numbers charts/calculators are for a minimally optioned truck.I did and it confirmed my towing capacities. When I ordered the truck I looked at the Ram website which showed higher towing/payload capacities. Now that I have the truck the capacities are lower. It’s the payload that is preventing me from towing the travel trailer I ordered.
