Adding Passive Entry: How-to
CHRISWARR36
I’ve got it all hooked up and I’ve done all the steps to change my settings, i unhooked battery for 30 minutes (twice now) and it still does not work. Does it take time for it to start working or did I screw something up. I believe I hooked everything up correctly and I turned on the settings noted….. any ideas?
vincentw56
Give it a couple of hours for the settings to show. Then turn it on through Uconnect.
CHRISWARR36
Didn’t work. I’m stumped as to what I’m doing wrong. Worst part is waiting each time only to find out nothing worked!
vincentw56
Do the settings show in Uconnect? If not, then you should check the settings in AlfaODB.
Two Yutes
Hampton Roads, Virginia
Just finished installing the passive entry here in eastern Virginia. HUGE shout out to Jimmy07 for the three wiring harnesses and to everyone that has contributed to this thread. I read all the posts and the install was involved, but fairly easy. My only hiccup is I think I may have stripped out the door cap screw threads. The screw started to get a little tight and then no resistance at all. The cap is on tight, but I hope I never have to pull it off again. My advice, be careful when you tighten the door caps. After using AlfaOBD the Passive Entry on both doors and the tailgate began to work immediately and within 5 minutes it showed up in UConnect.
CHRISWARR36
Finally got it to show up, drivers door and tailgate work bit not the passenger door. I’ll work on that tomorrow and try and figure it out.
dts828
Atlanta, GA
I spoke with Jimmy07 about this a while back and pulled the pins from the connectors to get the measurements. Last I heard, info on the rear door to body connectors is shrouded in secrecy as happens sometimes with manufacturers.
Easiest route to take is to run wires from the handles and then just feed the 2 leads through an open spot in the connectors (there are several). You will lose the ability to disconnect it easily, but it will work just fine. From there you just need to splice in to the wires along the floor to trigger the PE. I’ve got all the info, I just haven’t gotten to installing it yet.
I have been wanted to try this for awhile and asked if this would be possible. Do you of anyone that has gotten this work? Can you supply what and where to splice the wires into. I may need to order up handle to give this a try.
Jimmy07
Honorary Site Supporter
I’ve built harnesses for the rears for quite a few people here, but like mentioned, they need to be pulled through the main rear door connectors and tapped into the front handle wires. Let me know if you want a set.
dts828
Atlanta, GA
Yeah I'll send you pm, I guess you can tap into front handles by kick panel without having to go into actual front door?
MayhemMOORE
You can catch the wires right by the b-Pillar in the floor channel since they run from the RF hub on the back wall up to the front doors that way.
davebalaj
Hi All, finally completed full install and programming on my 2500HD. Everything worked as described and outlined here.
However, did anyone experience the rear backup camera not coming on when in R? Need to sort this out.
A big thanks to everyone who participated to make this happen.
Biggiehorn
Saint Cloud, FL
I just finished the driver and passenger doors. Activated the settings with AlfaOBD, and everything is working perfectly! I still need to add the antenna and wiring for the tailgate piece but I’ll knock that out when I get some time this week. Major shoutout to everyone’s contributions in this thread. This group is amazing.
@MayhemMOORE - really appreciate your dedication to this thread and all of your effort. Awesome job man.
@Jimmy07 - don’t know what else to say but thank you. Your harnesses are amazing. Top notch quality. Appreciate all you do for everyone here!
Jcardenas
If anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-
Im Interested in this harness how can I purchase them?
thank you
