chrisxtian
- Sep 5, 2021
Southern CaliforniaWhere are you located?
I’m just north of Tampa and plan on doing mine
Give it a couple of hours for the settings to show. Then turn it on through Uconnect.I’ve got it all hooked up and I’ve done all the steps to change my settings, i unhooked battery for 30 minutes (twice now) and it still does not work. Does it take time for it to start working or did I screw something up. I believe I hooked everything up correctly and I turned on the settings noted….. any ideas?
Riverside area willing to travelI know, SC is big
Do the settings show in Uconnect? If not, then you should check the settings in AlfaODB.Didn’t work. I’m stumped as to what I’m doing wrong. Worst part is waiting each time only to find out nothing worked!
If you want to take a trip to Las Vegas, I can do it.I'd pay someone to do this modification for me. I'm not that great at working with vehicles. Southern California area.
Sent you a DM.Riverside area willing to travel
I have been wanted to try this for awhile and asked if this would be possible. Do you of anyone that has gotten this work? Can you supply what and where to splice the wires into. I may need to order up handle to give this a try.I spoke with Jimmy07 about this a while back and pulled the pins from the connectors to get the measurements. Last I heard, info on the rear door to body connectors is shrouded in secrecy as happens sometimes with manufacturers.
Easiest route to take is to run wires from the handles and then just feed the 2 leads through an open spot in the connectors (there are several). You will lose the ability to disconnect it easily, but it will work just fine. From there you just need to splice in to the wires along the floor to trigger the PE. I’ve got all the info, I just haven’t gotten to installing it yet.
I’ve built harnesses for the rears for quite a few people here, but like mentioned, they need to be pulled through the main rear door connectors and tapped into the front handle wires. Let me know if you want a set.I have been wanted to try this for awhile and asked if this would be possible. Do you of anyone that has gotten this work? Can you supply what and where to splice the wires into. I may need to order up handle to give this a try.
Yeah I'll send you pm, I guess you can tap into front handles by kick panel without having to go into actual front door?I’ve built harnesses for the rears for quite a few people here, but like mentioned, they need to be pulled through the main rear door connectors and tapped into the front handle wires. Let me know if you want a set.
Im Interested in this harness how can I purchase them?If anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-
I believe you were the one I was chatting with on Instagram? Send Jimmy07 a PM. He’ll take care of you.Im Interested in this harness how can I purchase them?
thank you
