Randboye
I like your bed extender, what brand is that?![]()
Played recovery vehicle for a friends bike
Where did you get that from?Oil change before it get to cold. Little early but wanted to get the valvo max oil drain on too.
W
W
I had mine replaced 6 months ago so I could add the DASM. It is non-oem and it is perfect.Let me know if you have any issues with the aftermarket glass. I still need to get mine changed out as well.
ValvoMax Oil Drain System
Frustrated with your DIY oil change? ValvoMax removes the hassle. Replace your drain bolt with the Quick Twist valve. Made of solid 304 Stainless Steel, the valve simplifies your oil change. Save time, eliminate tools, and conserve the environment. Veteran-owned. Made in USAwww.valvomax.com
Cool, thanks!ValvoMax Stainless Oil Drain Valve - No Tools, No Mess, Fast Drain - for M14-1.50 - Stainless Drain Hose Attachment https://www.amazon.com/dp/B077Z9GQC...abc_WHST2Z68AS5AW7X9KNVS?_encoding=UTF8&psc=1
Looks like a updated version of the old Frame Sure-drain![]()
Thanks
how much for you make one for a 8 inch subLet the fun begin!
Got the box mostly built. Went crazy with the glue since the angles were a little tricky. I'll finish the caulk tonight and add the carpet and bolt through style terminals in the next few days. Managed 0.9 cu ft based on my redneck math.
It extends all the way to the other side of the cab to replace the factory cargo management system.
So, in the next few days, I'll finish the rest.
In the end I'll have:
- All five 3.5" infinity reference speakers for dash and ceiling (already installed those.
- CDT carbon fiber slim 6x9s for the front doors
- Infinity reference 6x9 2 ways for the rear doors
- Sundown Audio E-10 500w RMS subwoofer
- Alpine 500w mono amp
- PAC subwoofer interface module
- 72 Sq ft of 8mm butyl sound deadener
- 72 Sq ft of 150 mil closed cell foam sound deadener
My back and hands are sore just thinking about it all.
how much for you make one for a 8 inch sub![]()
, Too busy with work to go into the box building business. That's why this one is taking me so long. Plus, I recently shipped a small sub box and it was like 55 bucks just to ship. It's no wonder small businesses are dropping like flies.lol im ok with that 55 dollar charge if box is nice done i never done one, Too busy with work to go into the box building business. That's why this one is taking me so long. Plus, I recently shipped a small sub box and it was like 55 bucks just to ship. It's no wonder small businesses are dropping like flies.
What pictures are you referring to? I'm not seeing any pictures.So just confirm, the tires in these pictures are: 275/ 60/20 ?
I think this is the right direction to take, putting larger tires on the 22" wheels, rather than figuring out whether 18" wheels can go back on a Ram fitted with 22s. A neighbor friend who works in the 4X4 aftermarket said it wasn't possible? But were I ever to go off-road, I'd obviously want taller sidewalls and more ground clearance. How much lift did you get here? Was it a DIY, or did you have a shop do it? What was your cost? I haven't decided whether to sacrifice fuel economy, and I'm not yet ready to take my 2021 off-road -- undercarriage is very clean and very minimal scratches / marks. But eventually!
cad $2700 all in with veteran discount what would be 5% I guess.
Bigger cost more and it is worth it for me.
You will not be disappointed. I have Lasfit 6k bulbs and they are STUPID BRIGHT!6000k Motomaster LED bulbs in - will drive later tonight to see how well they do.
They definitely match the GTR switchback turn signals though![]()
Sent from my SM-G986W using Tapatalk
