av8tor86
Finished the Lasfit LED upgrade on all the bulbs on the truck.
Stunning!I added some burnt copper color to my badges to match the brake calipers. I love this color! Very unique and sparkles like crazy in the sunlight!View attachment 110937
Gotta love when it all comes togetherI added some burnt copper color to my badges to match the brake calipers. I love this color! Very unique and sparkles like crazy in the sunlight!View attachment 110937
Gotta love when it all comes togetherView attachment 110941
Thanks man I really appreciate that!!Well done sir! Visually appealing and very satisfying to ones inner OCD!
It’s primed, painted, and cleared with VHT products!Looking good. Is that vinyl overlay or paint? If vinyl where did you order from?
That’s a good burn you got there… I’ve done that more times than I care to admit, but my soldering iron is hot enough to sear and leave scorch marks.Busy last two days.
Got the CDT's in the front doors and the infinity reference in the rears.
The CDT's are down right amazing. I should have done these before getting ballz deep in the sub build, I may not have done the sub at all.
The infinitys are very bright and shifted my Soundstage to the rear, which I'm not a huge fan of. I may keep a look out for a better speaker for the rears. For now, they'll do..just set the fader three notches to the front. I have frequent rear passengers and the rear stock speakers suck bad. Probably has more to do with the factory crossovers.
Also got the sound deadening in the doors and installed the door panel inserts that came with my katzkin kit.
Little bit of progress on the sub box, taking my time and trying to make it look nice. It'll be two tone dark gray and black with a metallic silver trim separating the two colors, to try and tie into the silver on the doors.
Also, apparently solder irons are hot.. Who knew
For the pics...
Yeah man, I'm normally careful but I made a rookie mistake and left it on the bench to warm up, then forgot and leaned on it to grab a tool off the peg board.That’s a good burn you got there… I’ve done that more times than I care to admit, but my soldering iron is hot enough to sear and leave scorch marks.
Do you have any idea what 6x9’s you will use for the rear? I haven’t changed mine yet for the same reason you don’t like the rear infinity speakers.
My nicer one has a trigger to go hot, this one doesn't. My 10 yr old walked into the garage at that exact moment and got to see me dance and say some colorful words
Aftermarket apparently, and it has the camera/sensor thing mount on the new one exactly like the glass that's broken. Gonna lose the little ram head down in the corner though, sad.You getting an OEM or aftermarket windshield, and do you have a camera above the rearview mirror?
Let me know if you have any issues with the aftermarket glass. I still need to get mine changed out as well.Aftermarket apparently, and it has the camera/sensor thing mount on the new one exactly like the glass that's broken. Gonna lose the little ram head down in the corner though, sad.
LolYeah man, I'm normally careful but I made a rookie mistake and left it on the bench to warm up, then forgot and leaned on it to grab a tool off the peg board.My nicer one has a trigger to go hot, this one doesn't. My 10 yr old walked into the garage at that exact moment and got to see me dance and say some colorful words
As far as rear speakers, I'm going on a 6 hour drive, so I'll break them in a bit and see how it goes. Kinda limited on 2-3 ohm options, but I think something with a large silk dome tweeter would sound warmer. I think crutchfield is wrong and the kappas will fit.. They also say you can replace the rear ceiling speakers and they're wrong about that too. Otherwise, maybe I'd have better luck finding a 6.5" with a bracket.
I almost, and probably should have went with these
