Oil change before it get to cold. Little early but wanted to get the valvo max oil drain on too.
W
Where did you get that from?
ValvoMax Stainless Oil Drain Valve - No Tools, No Mess, Fast Drain - for M14-1.50 - Stainless Drain Hose Attachment https://www.amazon.com/dp/B077Z9GQC...abc_WHST2Z68AS5AW7X9KNVS?_encoding=UTF8&psc=1
Cool, thanks!
Looks like a updated version of the old Frame Sure-drain
Got all the boxes I need for this coming Monday! Cant wait to get the 4inch BDS , 35 Nitto grapplers with wheels and rotors put on. Plus I can finally get rid of all the boxes out of the garage.
Let the fun begin!
Got the box mostly built. Went crazy with the glue since the angles were a little tricky. I'll finish the caulk tonight and add the carpet and bolt through style terminals in the next few days. Managed 0.9 cu ft based on my redneck math.
It extends all the way to the other side of the cab to replace the factory cargo management system.
So, in the next few days, I'll finish the rest.
In the end I'll have:
- All five 3.5" infinity reference speakers for dash and ceiling (already installed those.
- CDT carbon fiber slim 6x9s for the front doors
- Infinity reference 6x9 2 ways for the rear doors
- Sundown Audio E-10 500w RMS subwoofer
- Alpine 500w mono amp
- PAC subwoofer interface module
- 72 Sq ft of 8mm butyl sound deadener
- 72 Sq ft of 150 mil closed cell foam sound deadener
My back and hands are sore just thinking about it all.
how much for you make one for a 8 inch sub 🥺🥺🥺
, Too busy with work to go into the box building business. That's why this one is taking me so long. Plus, I recently shipped a small sub box and it was like 55 bucks just to ship. It's no wonder small businesses are dropping like flies.
So just confirm, the tires in these pictures are: 275/ 60/20 ?
lol im ok with that 55 dollar charge if box is nice done i never done one ☠️
I think this is the right direction to take, putting larger tires on the 22" wheels, rather than figuring out whether 18" wheels can go back on a Ram fitted with 22s. A neighbor friend who works in the 4X4 aftermarket said it wasn't possible? But were I ever to go off-road, I'd obviously want taller sidewalls and more ground clearance. How much lift did you get here? Was it a DIY, or did you have a shop do it? What was your cost? I haven't decided whether to sacrifice fuel economy, and I'm not yet ready to take my 2021 off-road -- undercarriage is very clean and very minimal scratches / marks. But eventually!
It looks really good, photo is not doing any good haha.
I was out for black rebel 18” wheels to get more side wall. But the goal was to keep the look stock but with some muscles.
I am a week in with the lift and tires and I am so happy.
My lift is a 3.5 rough country with fox shocks.
35inch (true size 34.8ish) RT Haida 35/12.5/22
I had to delete the front mudflaps and use a tierip for the front wheel liners to kept the rub away. 1 min job.
I didn’t use spacers as this is already a half inch outside my wheel well. Unexpected but really happy with the results.
Everything is done in a prof shop. I paid here in cad $2700 all in with veteran discount what would be 5% I guess.
Ordered a Tazer dt to change my tire ratio and done.
MPG wise I have no idea. I don’t have any indicators on my dashboard that tells me the mpg. I just fill up when she needs gas and don’t let myself get triggered by the dashboard. I only keep miles to go visible Bigger cost more and it is worth it for me.
6000k Motomaster LED bulbs in - will drive later tonight to see how well they do.
They definitely match the GTR switchback turn signals though
Sent from my SM-G986W using Tapatalk
You will not be disappointed. I have Lasfit 6k bulbs and they are STUPID BRIGHT!
