Moosefire66
Ldc2335
Looks nice! Haven't decided if I am going to run the caliper covers yet. Ive ran them on several cars and never had any issues... I do think they are super overpriced. I've also had alot of success with POR-15 ceramic caliper paint that you brush on. It's thick and self levels for a powder coated looking finish.
That badge is pretty sweet.
Looks cool besides the stupid neon in the picture.
Is an all original SRT-4. Owner and I talked FWD turbo Mopars for a while yesterday as we have both owned Turbo Daytona's, and Spirit R/Ts.
Duran
I used the clips that came with the light bar. I used nylon spacers to clear that wire harness and the bumps in the ends. 1/4” spacers at the ends and 1/2” spacers in the middle.
Thanks for the info and follow up pics
MurphBigHorn
Install Mishimoto Oil Catch Can
Ldc2335
Scored a cargo rail set with cleats off a Tundra for 30 bucks on FB Marketplace. Had to trim a few inches off and drill some new holes, but it's on there and looks like it was meant to be.
gwatt86
What are the dimensions of the board you made? Looking to do something similar.
Ldc2335
Believe it was 67" wide.
1x10, doubled at the end. A any 2" board will would work also, but you'd loose 3/4 of an inch and gain twice the weight.
Also, if you use bedliner spray, prime the wood first and do light coats to build it up. It doesn't stick to bare wood very well. I'm thinking of redoing it with pvc board or pvc pipe, coated to look like a bed separator, but lighter and easier to remove.
Night Rebel
Atlanta, Ga
There the same type that ram uses cause I’ve used some of the toyota accessories for them. Looks good! Like factory.
ReLLIK75
How did you discover the crack. And was it the manifold or the bolts.
Very loud ticking tag start up. Took it to the dealer and they verified. It was both the manifold and the bolts that needed replacement.
Added the Luxe dark gloss taillight tint. Not sure if I should tint the backup lights.
Before....
After...
I contemplated doing the back up lights as well when I did my tint. I didn't use Luxe though because they have several negative reviews. I ended up tinting them. Looks better and it's not like they are that bright to begin with
