Knight.
Glad my 2 cents helped to get to the root of the problem lol.
68317978ALWhat module did you get?
68317978AL
My truck is a 19. It can’t be for the 8.4” because when I pull the fuse the screen isn’t messed up. Everything appears on the screen as it should. If it were the 8.4” Nav module my understanding is the display doesn’t show up right on the screen or it won’t show up all.Looks like this module fits 2019-2020 years. What year is your truck?
Also, I think this module is for the smaller screen and not the 12". I could be wrong if anyone else can confirm.
Well at least I know it’s not that.That Part number it's the one I'm using on my 2019 with the 12 " screen.
Enviado desde mi iPhone utilizando Tapatalk
I know of a few people that successfully used Jscan for the swap. It definitely sounds like the DCSD setting didn’t take, but the ICS setting did. Did you double check the current status of the DCSD in Jscan?Has anyone used OBD JScan to do the changes to the BCM?
Nice. How much did the module set you back if I may ask?![]()
2021 module came today and everything works! So that was definitely the issue with the camera. Took about 2 hours for everything to pull through.
