Gearjunkie340
I'm curious to know what you use and think about both apps in use with a security bypass cable.
AlfaOBD by a long shot. Jscan doesn’t “technically” support the DT Rams yet, but it’ll still work if you get a VIN license. Since you would be using BCM adaptations from a DS settings list, you’re limited to basic changes like fogs lamp dropout, remote start, etc, so you couldn’t add more complex features like surround view, adaptive cruise, factory LED headlights, etc. Jscan seems to focus more on updates for JTs and JLs. As far as how each app functions, they are both changing settings in the BCM exactly the same way, and both would require a security gateway bypass and interface. Also, Jscan is ~$25 for one VIN license, where AlfaOBD is $50, and can be used freely with an unlimited amount of FCA vehicles. One thing that is nice about Jscan is, it will scan every single module on the truck for faults in one shot, where with AlfaOBD you have to connect to each module individually, one at a time, to scan each one for faults. I don’t limit myself to one or the other though, as they all have advantages and disadvantages, so I use AlfaOBD, Jscan, appcar diagFCA, and auto enginuity.I'm curious to know what you use and think about both apps in use with a security bypass cable.
any update on this? Jscan work ok? review?Just FYI, JScan now supports the DT. Shows up to the 2022 year now. I think I’m going to mess with it tomorrow.
Jscan is the exact same type of tool as AlfaOBD, which can only toggle BCM settings that are already configurable.Anybody else try Jscan?
What features are you able to change vs something like the Tazer?
Hopefully Kill3Honks works on 2022’s.
I’m interested because Jscan works with iOS.
wait so I dont need to buy an android device to enable things such as passive entry and rain sense wipers, I can just buy Jscan on my iphone instead?Jscan is the exact same type of tool as AlfaOBD, which can only toggle BCM settings that are already configurable.
The 3 horn honk on the 22s is not a configurable feature, so no software like Jscan or AlfaOBD will ever be able to change that.
Tazer is able to do it as a live feature (has to remain plugged in) because it is actively monitoring/waiting for that message, and modifies it.
Yes, but you still need the security bypass and the device to connect to the obd port.wait so I dont need to buy an android device to enable things such as passive entry and rain sense wipers, I can just buy Jscan on my iphone instead?
You find anything else out on Jscan? I'm looking at getting something to change the tire size for new tires. I assume Jscan will do that.I have Jscan on iOS, has anyone with that setup been able to activate the off road pages? I have a 2020 Limited 4x4. Also, I changed the splash screen on start up, but cannot seem to change it back, any ideas on that?
Do you have to do any of the "multiple steps" with Jscan that are required for alfaOBD to change the tire size? With Alfa there seems to be some steps beyond to reset the ABS, etc. Wondering if Jscan is just put in the number and save.I use j-scan for tire sizes..works perfect. I really like j-scan. I have alfaobd too, but my daily phone is a iPhone so j-scan is real handy.
As Jimmy07 said before, the process for making changes is the same between alfaObd and j-scan as they both interface with the BCM is the same way, and you have to change each setting individuallyDo you have to do any of the "multiple steps" with Jscan that are required for alfaOBD to change the tire size? With Alfa there seems to be some steps beyond to reset the ABS, etc. Wondering if Jscan is just put in the number and save.
Thanks,
