jmrhodes212
- May 28, 2022
I don’t believe the steps or process in the software are the same. Just like he mentioned with checking codes, JScan does it differently and easier that AlfaOBD. I'm asking if JScan requires any extra steps in it's software beyond changing the tire size.As Jimmy07 said before, the process for making changes is the same between alfaObd and j-scan as they both interface with the BCM is the same way, and you have to change each setting individually
When you used JScan to change yours, what steps did you follow?
