tonneau covers that work with the multifunction tailgate?
1awesomelaw
are there any known tonneau covers that work with the trucks that have the MFT without removing the braces? i reached out to Bak and they said the braces would have to be removed to install their product
Diamond Back Covers work fine.
greenlawnracing
Truxedo Sentry CT and Extang Solid Fold 2.0.
My Sentry showed up Saturday, but I’m going to put it on because the factory liner has some discrepancies that the dealer is addressing. I would have preferred a hard folding design, but the solid fold does not go all the way up like a mX4
BlackBettyRamJam
Cedar Falls, IA
Installed a Truxedo Pro X15 Roll-up cover tonight. Fairly mediocre on fit. Installed with the stock bed brackets and the front of the rail doesn't sit flush with the bed rails so it's kind of angled at the moment towards the back. I was hoping it would fit similar to my Access Vanish on my old 2019. It's also not removable as advertised as they have to use bolts to attach it to the side rails instead of the sliding locks. Not a big deal for me but just not described well on their website for the multifunction tailgate.
O
Old member 1160
Guest
Installed the Truxedo Sentry CT on my 21 Longhorn Limited with MFT on Sunday. Main modification I had to do was to loosen the MFT brackets, and gently move down 1/4” with a rubber mallet. This allowed are more flush fit at the cab. Solid cover and looks nice in my opinion.
Lumpy55
I have the brackets and I installed the Bak flip MX4 with minor mods to the rails.
No issues. Looks and works great.
I also had same on a quad cab Laramie before i got my Limited.
Can you describe the rail modifications. I have an MX4 that does not fit my 2021 Limited with the 5'7" bed even though I ordered and installed the righton brackets. Before ordering the MX4 I spoke with someone at BAK who assured me that the MX4 would work using the replacement brackets. Needless to say, I'm not a happy camper at the moment!
Nomad
Wisconsin
I have the stock soft tri-fold on my limited. I want to replace it with a hard tri-fold but have not made the jump for these very reasons. I still can't believe non of the manufacturers have come up with something that will fit without any modifications for a truck with MFT and no ram boxes. You would think there would be a sizeable market for them.
ramtacular
I just successfully installed the Bak Revolver 4xs hard roll-up cover on my 2021 Ram limited with the MFTG. (no ram boxes). I simply installed the right-on brackets and then trimmed the front edge mounting flanges of the rails so the rails would fit over the right-on brackets. Took me about 2.5-hr including installing the right-on brackets.
NDThumper
We have the same truck and I've looked at their website, my question is how
does the cover bolt up on the factory support brackets in front.
Thanks.
Scottygolf
Minnesota
outside of the 6 brackets holding the rail on the bed, the Sentry comes with a long bolts that slides in the gap of the corner brackets. A large washer is included and bolts on on the other side of the bracket pulling the cover down to the bracket. Was an easy install once you go the rails to sit right.
greenlawnracing
I hope to install mine in the next month or so, do you have any pictures?
Scottygolf
Minnesota
Greenlawnracing - I stand corrected after taking a picture. The bolt head slides into the cover and the washer is on the other side of the rail (not the bracket). You access the nut thru the gap on the bracket
greenlawnracing
Thanks! Looks relatively easy.
I do not have BUG, but from what I understand the lack of rails will not be an issue
NorcalMike
Northern California
I don’t, as I’ve already sold it.
basically, on the rails that get clamped on the bed there are two layers of weather stripping. I peeled back the first layer (foam) and trimmed down the second layer (rubber) about 12” - which is the length of the bracket. If you don’t, the rails will be pushed inward not allowing the cover to sit flush inside the rails. If you have any questions, pm me a pic of the rails I can circle where to trim
Got mine installed yesterday. Didn’t trim anything. If we ever take it off it will take some finagling to get it back in but it’s fine. Doubt I will ever take it off much.
El_Draque
Installed the Truxedo Sentry CT today after my local shop told me that they absolutely could not order one that fits the MFT.... Ao i ordered it myself lol.. only thing is the instructions are unclear a bit. There is a plastic washer and nut instead of the big sliding clips, which is a bummer because i had to remove the clamps and re align the rails to get enough clearance for the nut to fit and in the future it will be difficult to ever remove it if i need the full bed. I also used scissors to cut the little rubber pads that sit between the end of the rails and the tailgate because if you open the MFT to the side it knocks those little pads off. Other than that im really pleased, it looks good and functions just how i expected and definitely works with the stock corner braces assuming you order the right part number (#1587016)
greenlawnracing
In the event that I ever get my truck back, i’m going to install the same cover. I imagine it will make sense once I have it out of the box, but do you have pictures or something else I can reference during my install?
SaintlySins
I ordered the Undercover Ultra Flex too. I've the MFTG and the RamBoxes.
I had questions about the fit/finish and how well it worked with the RamBoxes - so I called the manufacturer. The guy was knowledgeable and honest about not knowing one of the specific questions I asked, (I respected the honesty), but in a YouTube video, I saw an install that addressed my question and feel confident. Doing an install tomorrow or Thursday.
Thanks to everyone for posting your results. It's been very helpful in my choice.
NorcalMike
Northern California
Liked the light included with it. Didn’t really need it with the existing bed lighting but it makes it even brighter.
SaintlySins
More good advice ...
I hope it's something I can add after-the-fact. Heading to bed, will check in the morning.
Thank you again.
