silver billet
 - Apr 18, 2019
I've actually programed this on my Z06 with HP tuners. It's a scaling map called etc opening rate and a follower map to close the tb. The taser interrupts this signal and magnifies the throttle pedal signal by a factor of x depending on what setting you're using on the device. But honestly this is pointless because it dosen't truly matter what it does or how it does it or whether or not it changes the intended operation of the vehicle, FCA views his as tampering plain and simple so it does really matter what we think of the tazer.
That said, valvebody line pressure is directly tied to throttle position and opening rate. Depending on how much change is made it could negatively impact the transmission.
If you think the throttle pedal behaves I that simple of fashion, I suggest some reading in the HP tuners forum. There's nothing simple about this. The tazer dosen't remap thus function but the effects are the same which is why I called it what it actually is.
Putting a pedal commander on your truck has nothing to do with remapping anything. All it does is send out a little more voltage just like it would when you press the pedal farther.
I'm not talking about the Tazer. I was responding to somebody who was worried about using something like the pedal commander and voiding the warranty.
