295 or 285 tires for 20inch Ram rim - Discussion
Go with 35x12.50R20 ! The other sizes don’t have the girth the truck requires , I went the 295-60-20 and 285-65-20 on my 14 Ram and it looked sick until I went with 35x12.50’s - here’s a couple of pics of my 19 BIGHORN with 35x12.50R20 Thunderer Ranger ATr tires
12.5 rubbed the crap out of my control arm on the 4th gen and without a 4 inch lift it just looked to stuffed.
These are LT285/60/20. Little bit of a stiffer ride for sure, but road noise is pretty minimal. No rubbing, 2.5" lift
can you dm me or post a picture to see how flush the wheel/tire is to the flares? whats the offset of the wheels as well?
They are 0 offset wheels. I'll post a pic soon
I had absolutely NO rubbing whatsoever with my 14 with 35’s and 2” lift with stock wheels , if it would’ve rubbed I would’ve went with a smaller size or lifted a little more, I did use 1/4” spacers though, my 19 is setup the same identical way with no rubbing, I can’t take it anywhere without people complimenting on it! Here are some pics to prove it
Went Lt 275x60r20 Falken wildpeaks At3w on Ram black wheels. These are D rated 8 ply and measure a bit wider then the 4ply P rated.
P rated is 33x10.8 vs D 33x11 per falkens website
Before and after pics included
Stock for me was 275x55r20
Sent from my SM-G998U using Tapatalk
My wheels are +1 offset too! Fuel Contra 20x9 +1....and I think I am still getting a little rubbing depending on the angle of the turn and elevation.
Have you got any side on pics to see the +1 offset?
