So trolling this thread, since I'm exploring options because I'm tired of waiting for the Mopar 2" lift to come in (>2 months).  We're in beach season and I haven't had the truck on the sand once.  Also want to get this done before fall/winter.
I'm interested in having the truck level and eliminating the front end rake.  I don't haul much or tow much, so I'm not worried about the squat issue.  1/2" rake is acceptable.
So confirming what I have read in this post, setting the clip to 6, 7 or 8 would get me level?
@DOFF your truck looks damn level to me, so clip 8 looks like it will get me what I need.  And that's a non-ORP package/springs truck, correct?
I also have a set of ORP springs in my garage that I was going to use for the Mopar kit, can I still have those installed instead of the springs with the kit?  I surmise I will need to get a set for the rear to match, but the springs were inexpensive, so that shouldn't be a problem.
I might upgrade the UCAs while I am at it and they have the front end apart.
EDIT:  I did the math and here's my measurements from center hub to fender (and no, I didn't make up them being spot on identical.  I was shocked to see they matched, but then again, I don't drive much):
Front D/S: 21.375"
Front P/S: 21.375"
Rear D/S: 23.250"
Rear P/S: 23.250"
So the delta is 1.875".  If I add the ORP springs with this install, that brings the delta down to .875" (naturally, because the ORP spring eliminated the 1" extra).
So I think I might have answered my own question, if I install this without the ORP springs, I'm looking at clip position #6 (1.9").  If I add the ORP springs, I might still do clip position 6 or even 7 to get closer to closing the rake gap.
