View attachment 93487View attachment 93488
Here’s my before and after. 6112s up front set at clip 8, 1” to the rear leaving me with 1/2” of rake.
Looks great! I like those black rhino wheels, they’re super lightweight!Installed some 6112’s today. Clip 7. 285/70/18 -18 offset. 0 rubbing.View attachment 134763View attachment 134762
Nexgen!Nextgen offroad?
Nexgen!
Where are you guys finding the 6112 in stock ?
Curious to hear the answers. I was looking at the loaded ones too. Are you hoping to be leveled or end up with a slight rake?Really debating on ordering these up and doing clip #6 for 1.9".. looking at loaded ones, does the 1.9" hold true or will it end up being more? My truck is a non ORP Laramie, I am aiming for around 2" up front and looking to add ORP springs for the 1" in the rear (set for rambox/multifunction gate) as they have a touch firmer spring rate to aid when loaded/towing) That lands me with running stock wheels as the wife and I like them well enough. But trying to decide on LT295/55R20 (32.8" tall; 12.2" wide) OR LT295/60R20 (33.9" tall, 11.8" wide) in a Toyo Open Country AT 3 or BFG AT KO2. Anyone running that set up by chance. I have been searching but not a lot of luck. I know most are probably not doing the ORP springs out back as they want to kill all the rake, we just need some rack as we use the truck.
I’m tuning 275/65/R20’s BFG KO2’s on stock ORG with the decked drawer system and topper. I think what your looking at would land you about 3/4-1” higher in the front and about even as me in the rear if your looking for a close visual. Best I can do for now. Looking to add the Carli commuter soon hopefully.Really debating on ordering these up and doing clip #6 for 1.9".. looking at loaded ones, does the 1.9" hold true or will it end up being more? My truck is a non ORP Laramie, I am aiming for around 2" up front and looking to add ORP springs for the 1" in the rear (set for rambox/multifunction gate) as they have a touch firmer spring rate to aid when loaded/towing) That lands me with running stock wheels as the wife and I like them well enough. But trying to decide on LT295/55R20 (32.8" tall; 12.2" wide) OR LT295/60R20 (33.9" tall, 11.8" wide) in a Toyo Open Country AT 3 or BFG AT KO2. Anyone running that set up by chance. I have been searching but not a lot of luck. I know most are probably not doing the ORP springs out back as they want to kill all the rake, we just need some rack as we use the truck.
I use it for a truck and def. need some rake in the truck for loading and towing. 2" (1.9" for the 6112s) in the front and another inch in the rear (VIA ORG Springs) is what will likely be happening. just need to decide on tire size for a 33 maybe a 34.Curious to hear the answers. I was looking at the loaded ones too. Are you looking to be leveled or end up with a slight rake?
Hey I know this is an older post. But I’m just wondering if your setup with the bolstering and 35s fit well as is. ThanksI just got a set of 6112/5160... not installed yet. I'm looking at doing clip setting #4 or #5. I know most are probably doing #6-8 but I don't have ORP and I think 1-1.5 inch lift is enough for me.
Any thoughts, or similar setups that have been done, let me know! I will post pics when I finally get them installed....
Finally got around to installing my 6112s on the front. I went with clip #4 to preserve some rake and suspension droop.
The front raised just under 1 1/4" at this setting.
This is the factory non-orp Hemi 4x4 Crew Cab suspension.
Before:
After:
