I'm a "self-proclaimed" audiophile. There is some degradation, but nothing too noticeable. Nothing that outweighs the benefits of going wireless (my personal opinion).General reviews I've see on these devices are that the audio quality for music isn't that great. Anyone have an opinion as to if this?
Thanks. I did order on and will soon hear for myself!I'm a "self-proclaimed" audiophile. There is some degradation, but nothing too noticeable. Nothing that outweighs the benefits of going wireless (my personal opinion).
GatorB8,Got the CarlinKit installed today, and works great.
Anyone try using a USB-C to USB-C cable yet?
I was thinking of ordering a 90* one to try to clean up how the connection looks.
Just an update, I don’t think I clarified that this was on a carplay2air unit. I ordered a carlinkit 2.0 and got it setup today and it seems to load faster than the carplay2air unit did. The load screen is also different. This one is red and the carplay2air was green with a little different graphic. I’ll update if I notice anything else different or any problems arrive.I updated to the newest version and was having a problem where Siri would start saying my text message and then the audio would cut out before getting the whole message. I noticed there was a setting to roll back to the previous software version and ever since then it’s been a brick. Does anyone know how to get it working again?
As I mentioned above in another post, it would be great to have a short (8 in.) USB-C (rt angle) to USB-C (rt. angle) cable. The problem that I encountered was the narrow opening on the Carlinkit side.Got my Carlinkit 2.0 and connected it today. The only way I can get it to work at all is using a USB-C to USB-C cable I had. The small cable provided in the kit doesn't seem to work no matter how I connect it, C to A(truck) or A to C(truck). I suspect cable is bad or It's just not getting a solid connection cause it seems kinda iffy and lose Imho.
I happened to have a white C to C cable that fits and works fine. I just ordered a 1' black cable from Amazon that I was told has very small housing around each jack that I'm expecting (hoping) will fit the opening also. Not right angle however.As I mentioned above in another post, it would be great to have a short (8 in.) USB-C (rt angle) to USB-C (rt. angle) cable. The problem that I encountered was the narrow opening on the Carlinkit side.
Please let us know if anyone located a cable that works.
Will this play video from your phone?I just came across this today. Someone may be interested. Save $30.00 use code....[ SAVE30 ]
🔥Carlinkit 3.0 (U2W plus) Wireless Adapter for Factory CarPlay Convert Factory Wired to Wireless CarPlay🔥 - Carlinkit Factory Store
Carlinkit 3.0 Wireless Carplay Dongle is Simple And Easy To Convert Your Wired Carplay To Wireless! Simply Plug-In Our USB Adapter Into The Factory USB Port.www.carlinkitfactory.com
You got the Carlinkit 2?I ended up buying one of these and so far I'm pretty happy with it. I did test the plug/unplug scenario going from wireless to wired CarPlay and vic versa. What I noticed is that CarPlay does disconnect briefly when you plug in the power cable to the phone when it starts out as wireless, but then when you disconnect from power everything stays on. I was curious because I'm guessing on longer road trips I'll probably plug in to keep the phone topped off, while on shorter trips the wireless charger seems like the way to go.
So far, it's working mostly so good. My Carlinkit2.0 did seem to get confused yesterday when I remote-started the truck and phone wasn't yet in the cab. When I got in it seemed confused, took me unplugging the dongle, turning truck off/on, and just waiting for it to un-confuse itself. Next time I'm just going to wait a bit longer and see if it clears on its own.Got this C to C cable from Amazon and it seems to work fine.
https://www.amazon.com/dp/B07THFJ1J5/ref=cm_sw_em_r_mt_dp_Y7XHE26WKHVQMGF5E3NA?_encoding=UTF8&psc=1
I bought a similar cable and used a razor to trim it. The C-C did not work in mine, would get power but would not connect.GatorB8,
Please let us know if you find a USB-C to USB-C (rt angle to rt angle). I tried to clean up the connection as well.
I tried the USB to USB-C listed here and it DID NOT FIT into the slot on the Carlinkit dongle. The plastic molding is too thick around the actual connector.
Amazon.com: CERRXIAN 9 inch Gold Plated USB Left & Right Angle 3.0 Type C Male to Left Angle USB Type A 2.0 Male Fast Charge and Data Sync Cable L : Electronics
Buy CERRXIAN 9 inch Gold Plated USB Left & Right Angle 3.0 Type C Male to Left Angle USB Type A 2.0 Male Fast Charge and Data Sync Cable L: USB Cables - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
It appears that the USB or USB-C connector works for the "truck side" of the connection.
same problem, would love a fixMy Carlinkit 2.0 is working great. It connects in a very short amount of time and I have only found one issue.
When I receive a call, their is no "ring" to alert me. The screen changes to phone mode, so I can see there is a call coming in.
Has anyone else experienced this problem?? Do you have a solution??
-G
Maybe your C-C cable isn't a data cable, just power. My C-C data cable is working fine, no issues that I have found.I bought a similar cable and used a razor to trim it. The C-C did not work in mine, would get power but would not connect.
