2020Big4x4Horn
- Jul 19, 2020
YesOkay and to be clear you went from a 23 gallon tank to a 33 gallon tank correct?
ok thanks for the info...i do have the level 2, so i guess he is doing something wrong... i don't understand why he would not want to do it for me. its not like they are busy ATM they hardly have any vehicles to sale on their lot.In order to add it you must also add either the Level 1 Equipment Group or Level 2 Equipment Group. If you have one of those then you add Sales Code NFF to get the 33 gallon tank.
Here are two Build URLs that reflect without the 33 gallon and with the 33 gallon tank. The only difference is the NFF sales code.
"https://www.ramtrucks.com/bmo.html#...X8,EZH,DFR,DMC,DSA,Z6D,TUM,WBB,E1,A62,UAM,25Z"
"https://www.ramtrucks.com/bmo.html#...ZH,DFR,DMC,DSA,Z6D,TUM,WBB,E1,A62,NFF,UAM,25Z"
Hopefully this helps.
I can upgrade like you said. It just alot cheaper when its done during the build.. i think 495. No hassle doing the computer sales code and suchYou should be able to upgrade it yourself once you get the truck with the parts and directions identified in this thread.
It may be a matter of how early of a 2020 you have. The key is likely the vapor tube you take off. You can see the one I took off and the 57008595AA part are shaped the same on the right side of the picture - a rounded bend and an additional 5 inches to the connector.That is odd, I used 68307831AB on my 2020 5.7l and it fit perfectly. It wasn't tight or crimped, seemed like the right part.
so did you buy the parts for wholesale?Nice detective work, Biesty. Strange how there's so much discrepancy in these part numbers. The part number I used is 57008588AA and looks like the shortest one, and fit perfectly on my 2020 quad cab. I hate how there doesn't seem to be a definite answer on which ones are meant for which exact trims/options. Thankfully everyone else up to this point has been lucky (that we know of), getting one that works for them. For everyone else having trouble finding a mopar wholesaler site with good fitment descriptions, I've found factorychryslerparts.com to be the most helpful.
I get my parts through my family's body shop. They get better prices and free shipping on parts than online stores. Most folks I've seen seem to buy their parts online.so did you buy the parts for wholesale?
How do i get in on this family discount?I get my parts through my family's body shop. They get better prices and free shipping on parts than online stores. Most folks I've seen seem to buy their parts online.
The reason your part was a different number is because you have the Quad Cab. By going to the site you provided it lists the correct parts for the Quad cab and which one is for the 33 gallon tank.Nice detective work, Biesty. Strange how there's so much discrepancy in these part numbers. The part number I used is 57008588AA and looks like the shortest one, and fit perfectly on my 2020 quad cab. I hate how there doesn't seem to be a definite answer on which ones are meant for which exact trims/options. Thankfully everyone else up to this point has been lucky (that we know of), getting one that works for them. For everyone else having trouble finding a mopar wholesaler site with good fitment descriptions, I've found factorychryslerparts.com to be the most helpful.
Actually, I recently discovered there is a crossmember that can be used and would give you what you are looking for. It is #22 in the diagram below. You can bolt this up without the longer skid plate and accomplish what you want but it is the crossmember for the longer skid plate to give it strength up front. The part number for the 33 gallon skid plate is 52029964AD, the crossmember part number is 68348386AB and the part number for the four hex nut/retaining clips to hold up the crossmember is 06508646AA. You will also need 4 M10x1.50 bolts to bolt the crossmember to the frame (I forget what length I bought). If you are bolting the skid plate to the crossmember you will need 2 more M10x1.50 bolts. Once in place this crossmember is plenty strong enough to be used to add support for the tank (it sits about 1" below the tank).Since some folks are running without the third bracket without any issues. I wonder if just changing or adding the 33 gallon skid plate with some sort of spacer /block between the tank and skid plate would be sufficient. From what I remember the skid plate should be strong enough to support the addition weight without flexing. Perhaps another option????
Optional. Only if you want a plate to protect the underside of the tank. I had the skid plate on my 26 gallon tank and wanted it for my 33 gallon tank so I ordered one.Do I need the skid plate? Don’t have one on the 23 gallon now
