@Rammit
Just got my truck back. They didn't flash the ECU to read 33 gallons to empty correctly. The tech said they didn't have the ability to do it. That's not what I was told at the start of this. So now I wait for the service manager to call me back. Worst case scenario I do it myself with Alpha OBD. Never used it before and heard it works with android so hopefully if I have to go that route I can do it with my phone.
Also some things to note. My Rebel has factory skid plates. I had to order a longer skid plate for the 33 gallon tank to cover the entire tank part# 52029964AD. Apparently there is also another smaller bracket that helps support the length of the skid plate and bolts needed.
1 - 68348386AB - Crossmember bracket
4 - 6508646AA - Nut hex bolts
2 - 6512090AA - Nut hex bolts
Just like the 3rd strap support, except this helps support the extra skid plate length.
Right now until my rebel fuel gauge is corrected, I'm guessing it will go to "empty" but not actually be empty. So I'll have to sort this out with Alpha OBD if the dealer can't. I better start reading up on Alpha OBD to be prepared.
Lastly I'll need to get a custom 3rd strap welded in. I tugged on the tank a bit (at the end of it where it's unsupported) and it feels well supported with a full tank and only 2 straps, but I'd feel better with the 3rd strap being there.
Overall there is quite a bit of stuff that needs to be done in order to do the switch from a 23 gallon tank to a 33 gallon tank. Especially if your truck has skid plates like the rebel does. Lesson learned, I will never buy a truck again with the tiny tank! I'm just glad there is a work around even if it's tedious and more costly than I'd prefer.
So far I'm into this $1,005.60 for parts and $160 for labor (dealer gave me a killer deal for labor due to warranty issues and 23 gallon tank not going to full). All said and done this is going to cost me about triple what it would have cost just to get it from the factory stock. Again hard lesson learned. Just glad its fixable and not bad enough I'd have to do a trade in lol.
