2021 Gas Milage
dunehiker
I've had my Rebel for about a month now and ~900 miles and so far I'm averaging ~16 MPG. That's with about 50/50 mix of highway and city driving.
space4092
CANADA - ONTARIO - SARNIA
Hi there,
I took my new 2021 Ram Rebel for the first road trip north and was a little disappointed by the fuel economy. I got 15.5 miles per gallon, and it supposedly does get 20 mpg. I had a Durango SRT before and if driven at 75 miles per hour got 18.8 mpg, and the Durango had a 6.4l V8. The Rebel ECO mode going to 4 cylinders does not seem to kick in at those speeds at all.
Scram1500
Hi there,
What's your experience? What fuel mileage do you get?
That would be from the knobby tires and 3.92 gear ratio on the Rebel. The 20 mpg on sticker is based on a 2wd Tradesman, eco friendly 32 inch tires, 3.21 gears, downhill, 105 lb driver, 2 gallons of gas, and a tailwind. They probably left the spare behind too.
All kidding aside it should get a little better after break in and keep it at 70 on the highway
space4092
3100 km, have switched to Synthetic oil... still improving. This is mostly highway...
What's your average km/h?
I do this trip up north quite a few times and did 871 km in just under 8 hours, with 15.1l on 100km, was doing 120-130 km/h
Zeeya
Lafayette, LA
Hi there,
One thing I noticed my eco light came on a few times, but after I got about 4000 miles it I saw it a lot more on the same roads. Not sure if computer is setting up driving styles or not.
Took my bone stock bighorn with a 5.7 plain jane up through the PA mountains to wine country this pass weekend. Pulling a 17 ft bass boat I managed 16.7 mpg on the way north. Drove home empty and averaged 19.4 mpg. That's running up with the cruise set at 70 and home with the cruise at 75. Also took a trip down the PA turnpike about a 130 mile haul, empty, averaged 18.4 with the cruise set at 80. It depends greatly on speed and driving habits in my opinion.
Jako
Borough of Parks
Agree. I've done 400 mile trips from southern tip of NY to Buffalo and have done a bit better (20+) by doing the speed limit and no traffic.
chuck01835
Rebel with 6 inch lift and 37s. Stock from I was getting around 15.9. As it sits now 14.0-15
Did you recalibrate for tire size? If not, you are probably getting more mpg as each tire revolution goes further distance so it could be underreporting the speed and distance.
CDKinNoVA
Best MPG thus far, road trip to Long Island....5.7 Hemi, low grade gas (10% Ethanol) IMG_3475.JPG
theblet
Between 45 and 60mph is a sweet spot for mds, as long as the road is pretty flat and no head wind. Set the cruise as much as you can too it’ll help.
Luvmymopar
I
Either your friend is telling a slightly white lie or he is driving even more conservative than you. I get about 13 mpg, that's with 60% city / 40% highway. If I hypermile it, I can get up with maybe 17, even 19 mpg highway with MDS operating.
If you search other mpg threads regarding Rebels, your mpg is about right. However the Hemi is known as a tight motor that gradually "loosens" up over time and improves mpg a little, but not anywhere near enough to match what your friend is doing.
As for me, I knew what I was getting into. 33" A/T tires, 1" suspension lift and 3.92 rear axle means terrible mpg. Your window sticker mpg is a lie, FCA blanket stated based on similar configured truck (i.e. crew cab, 4x4), but with 18" street tires and 3.21 rear axle. They are allowed to do that, but it's downright shady. At least GM bothered to adjust their Trail Boss packaged trims down a little because they come with 32" tires and off-road group and knew it wouldn't come close to the regular truck mpg.
The reason why FCA doesn't care is because they are already having issues keeping their CAFE numbers down, already buying carbon credits from Tesla by the millions, they can't afford to classify Rebels with accurate mpg figures.
Have a 2014 tradesmen 5.7 hemi that gets 22 on the hwy and my 2021 rebel gets 16.5 the 14 runs like a bat out of hell but doesn't look near as good or have awesome 4wd I'll keep recycling cardboard for the environment and drive a BA truck that drinks gas like whiskey smiling the whole time
cnstoll
Took the new 2021 Rebel out for a 250~ mile road trip on Saturday. With a mix of city/highway/rain driving it averaged out to 16 MPG, Hemi with eTorque. 16 seems to be roughly the average I've seen a few other people post, so I wasn't too surprised with that. I'm betting it'll be a little better than that on a real cruising road trip (this one had a lot of stops).
WS6 #3392
I just got my Rebel last Saturday so it is still below 600 miles. I travel about 38 miles one way to work, so about 76 miles a day. My average speed is about 45. I am getting 18.2 mpg right now.
