So you want to tow a camper! Discussion thread.
Jcarroll8907
56ECD360-2B7C-4FD5-BC10-5EA433FFAF36.jpeg 19 rebel non-air suspension with timber grove bags. 1650ish payload, don’t remember the exact door number. 720 on the tongue here based on the scales. + 200 cap, 350 passengers, 80 dogs, 100misc truck stuff...200lbs of leeway, we’ll within specs all around.
Uga40
Just installed some ride rite coil spring bags, thought i would share a before and after. It made quite a difference in the ride and squat. My tongue weight is around 700 lbs, TT is 26ft hitch to tire and 5,300 lbs. Using a Recurve r3 WDH
silver billet
Did that change your unloaded ride quality at all?
Willwork4truck
SC
Actually looks a bit high on the after picture (the nose of the trailer). That could induce sway.
Big Dave TX
Houston-ish
Haven't noticed a change yet. I release the air in the bags and inflate them to 5 lbs PSI without a trailer and 50 lbs PSI with the trailer
I'm very interested in your "after" ride comfort. I have Timbrens and it's great when I tow but the rest of the time, not too happy.
Uga40
What PSI do you keep it at unloaded?
Uga40
He has Timbrens no PSI to adjust
Ahh, just looked at those. No mine are ride rite bags that go in the springs so you different products all together.
jsxtreme01
Uga40...what Imagine XLS do you have? Looking at getting the 21BHE
LoudHogRider
22MLE
Just bought one yesterday as it's just the Mrs. and I these days and it looks like a really great "couples coach". Sadly, I won't be able to pick it up until mid-May as the RV dealers are overwhelmed with demand and that was the first available window for dealer prep, adding an exterior coating, etc.. Looking forward to the ownership experience and to SAFELY towing it based on insight I've learned here on the forums (e.g. how to install the trailer brake, load capacity, etc.).
devildodge
Moderator
Central Pennsylvania
Better start seeking reservations. The RV dealers are busy and the campgrounds are packed. Good times
