First post... but I've been lurking as I work on swapping from an F150 to a Ram.  I'm active on a few of those forums, hope to have a reason to contribute here more in the near future.
The journey has raised some payload concerns, as the way things are I'll have to order mine, and won't know the payload sticker until it arrives.
Therefore, I've gone through most of this thread and other nooks of the internet and put together the attached spreadsheet.
It starts with the base weights on a 4x4 Crew Cab Tradesman 5.5 V6, and then you add the options you have/want in yellow.  Weights are direct form Ram for 21 MY.
I've taken the option/package weights from this forum, but there are a few I'm dubious about (e.g. I'm skeptical the MF Tailgate is 75lbs
beyond a standard tailgate?), so feel free to change weights as you see fit.  Man, it adds up quick!
However, I have audited this against a pretty fair sample of the reports & stickers in this thread, and for the common packages it seems to be dang accurate, always in the ballpark +/- 100lbs.  Those results are in the Green section.
Since half tons are always payload-limited (vs Tow Rating or GCWR limited) whenever there is more than just a driver & a Snickers bar onboard, I've also put in a "Real World" tow limit at the bottom.  Just plug in your tongue weight (10% min, 13%-15% ideally) plus cargo & passengers, and you'll see what you can do before invoking the ire of the Payload Police.
Now it means I have to decide what to cut back on.  My F150 has every creature comfort and still near 1,700 lbs payload (and it rides like ****e unloaded as a result).  But that's
all it had over the Ram, I am looking forward to literally everything else the Ram does better!
					drive.google.com
Enjoy.
